Cooktops Logo
Anonymous Posted on Jan 18, 2013
My induction cooktop isn't working. When I push any of the touch pads, the numbers flash. There is no E for displayed, only the various numbers I push.
The unit is about 3 years old and has had no previous problems. I tried turning off the power at the breaker box for 30+ minutes to no avail. The model number is CIT 304 GB
Bill Dickerson
Level 3:
  • Master 979 Answers
  • Posted on Jan 30, 2013
Bill Dickerson
Master
Level 3:
Answers
979
Questions
0
Helped
309269
Points
2196
Call the co. And let them guide you thru this. Does your instruction manual give you any help. Hopefully, your board hasn't gone bad.
2 Related Answers
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Feb 18, 2010
SOURCE: cooktop is locked out on
Hi and welcome to FixYa. I am Kelly
I could be of much better help with a complete model number I.e. (example 110.XXXXX)
The wait is supposed to be 10 minutes. go back and turn off your breaker by "Physically" pushing it with conviction to the OFF position and wait 10 minutes.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
If it does not go out I will need your model number to go any further.
Thanks for using FixYa and I will be watching for your response.
Kelly
Anonymous
  • Posted on Mar 09, 2010
SOURCE: cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Eo1 code on a scott omcan induction cooktop
Try this
  • Error code E01 showing on display
  • What causes an E01 error code on the CT Electric Cooktop control panel?
  • CT E01
STEPS TO VERIFY ISSUE:
Turn the home circuit breaker to the unit off for 30 seconds then back on again. Then retest the unit operation.Or contact the maker direct. They are expensive units and in my experience, if you get 2 years out of them in a commercial setting, you are lucky!
INDUCTION COOKERS - Omcan
omcan.com > ... > INDUCTION COOKERS
INDUCTION COOKERS. Home FOOD EQUIPMENTCOOKING EQUIPMENTINDUCTION COOKERS. Name, Date, Price (ASC), Price (DESC), Item Number.
Mar 11, 2021 • Cooktops
Power went out. reset circuit breaker and all the lights keep flashing 8.8 and won't stop
Hello Heidi, thank you for your post!
From my understanding your Electrolux cooktop is displaying an error code of 8.8. The error code of 8.8 means there is a shift register issue on the middle touch board. This could a possible issue with the control board or the middle touch board. You may need to have a professional technician out to your home for proper diagnosis. We hope this information is helpful to your repair. -Matt
1helpful
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
Induction cooktop
Could be the child lock turned on
Jul 02, 2013 • Cooktops
2helpful
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
How to un lock my GE Profile Induction cook top?
Try turning off the breaker for at least 10 min and re apply power. If this doesn't work, then there's an internal problem.
31helpful
2answers
Wolf Induction cooktop is locked in Showroom mode
If Shr (5hr) appears on the display then the cooktop is in showroom mode. To exit showroom mode the cooktop must be locked by pressing and holding the key symbol for 5 seconds. After the cooktop is locked, press and hold the melt touch pad for 5 seconds.
6helpful
2answers
Cannot turn on cooktop.
I have a Kenmore Elite Induction Cooktop and we had some milk boil over and now the cooktop is locked. How do you unlock it?
Top Thermador Cooktops Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
