Question about Sewing Machines
Janome v 74088 627 pattern selector stuck - Sewing Machines
I need an instruction manual for an old Janome sewing machine.
you can search Google for a make,model,manual .GOOD LUCK and print one that looks real close to your machine .
Nov 12, 2015 | Janome Sewing Machines
I need an instruction book for serial number 641041095 please
The model number may be in the name, ie Janome Dream Quilter. Also, look for a plate, badge, or even a number stamped into the case.
Search the internet for:
Manufacturer + Model + the word "Manual"
Nov 11, 2015 | Janome Sewing Machines
Why is my Janome Mystyle 20 stuck on reverse?
It may be in the buttonhole mode, change the stitch selector to straight stitch.
Jul 16, 2014 | Janome Sewing Machines
Janome 6125qc
Although you have selected a zigzag have you also set the stitch width and length manually as required? Some stitch types have restrictions on the width you can set so it's important to know which these are.If you don't have the instruction book it is available as a free download from Janome. Go to www.janome.com, click on the Machines tab then choose 'retired' and scroll down until you find the 6125QC - the link to the user guide is in the top right corner of the specifications tab.
Nov 02, 2013 | Sewing Machines
Don't know how to do button holes
Slide the back of the buttonhole foot "R" open, place your button in the cradle and slide the fott together so it holds the button.
Snap on the buttonhole foot on the machine. Pull down the buttonhole lever. It has a small white plastic paddle on the end and is located up and to the left of the needle bar. Pull the lever all the way down. Turn the pattern selector to Buttonhole. Place the tension on 3. Place the stitch width control on 5 or 6. Place the stitch length control a little below 1. Make sure that you have some stabilizer between the layers of fabric. Use freezer paper in a pinch. Lower the foot on your fabric making sure that the foot is not pulled forward or backward. Make a test buttonhole. AFTER EACH BUTTONHOLE YOU MUST TURN THE PATTERN SELECTOR OFF BUTTONHOLE AND BACK ON IN ORDER TO RESET THE MECHANISM. Make several test buttonholes, adjusting the width and length if needed.
Jun 02, 2011 | Janome D'cor Excel 5018
Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Feb 21, 2010 | Singer Inspiration 4206
Downloading emb. patterns to a memory card
Hello
You need the Memory Craft Reader Writer before you can copy to a Memory Card, I bought for my Janome 5700 and it works great.
Apr 21, 2009 | Janome Memory Craft 5700
Singer ingenuity stitch selector stuck
pull the button hole lever all the way down, then push it all the way back up. Select your pattern and it should work.
Sewman7
May 13, 2008 | Singer 7436 - INGENUITY
Sewing Machines Logo
85 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
