Question about LG WM-2277HW Front Load Washer
I have an LG WM2277HS front load washer. It wasn't pumping any water out and making a rattling sound during the drain phase. I cleaned all the hoses out and still no water being pumped. Made su
    Problem Solver:
  • 14 Answers
Check if there is a piece of cloth stuck between the drum pipe and the drainage pump
Posted on Jan 25, 2013
3 Suggested Answers
SOURCE: LG front load washer WM2277HS.
it is leaking and make crazy noises
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 26, 2011
LG WM2140C front load washer overflows during drain cycle
This sound like the water is leaking from the drain pump.
Dec 22, 2012 | Washing Machines
My lg model wm2277hs won't rinse water stays after washing
you need to ck the filter in the front down at the bottom left corner of the washer if it is clean you will need a new drain pump motor
Nov 02, 2012 | Washing Machines
How you can replace the water pump motor for wm2277hs washer
Hi Maria.
The pump is located in correspondence of the front bottom side of the machine. Behind the pump filter access.
The pump is screwed to the internal side of the chassis. The procedure to replace the pump is illustrated here.
Aug 13, 2012 | LG WM-2277HW Front Load Washer
Have an LG Tromm WM2277HS washing machine the water will not drain and of course will not spin
heatman101
Sep 10, 2011 | Washing Machines
Got an LG front load washer WM2277HS with an error OE. Verified no clogged filter or drain problems. When the cycle starts for it to drain I can hear the pump turn on but with a clicking sound as if the...
Replace the Drain Pump. Its very cheap to replace, so do not worry. The impeller magnet was most likely damaged by a small object or normal wear & tear,
If you want to be sure, first remove it and attach power to its 2 pins.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Feb 16, 2011 | LG WM-2277HW Front Load Washer
LG WM-2277HB washer does not drain and make rattling noise.
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall to allow access to the pump through the large rectangular hole in the base of the washer. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 4.5 or a 5. Not too bad.
Leaking is rarely, if ever, caused by the drain pump. Small leaks can come from using too much soap, which backs up in the dispenser area and leaks down inside the machine, or larger leaks from a cut in the door gasket.
Apr 04, 2009 | LG WM2277HBW XL Front Load Stackable...
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
LG WM-2277HW Front Load Washer Logo
263 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
