Question about Samsung WE357A0W
Samsung DV400G compatible pedestal - Samsung WE357A0W
Fix pedestal for samsung 740BF
you can buy a wall mount for under 12 bucks. Or alternately you can buy an VESA 100 mm compatible stand for about 30 bucks
There're are out there lots of solutions for LCD, arms for mounting in desk, wall or poles.
Mar 22, 2014 | Samsung Computers & Internet
Can I use a frigidare pedestal model number apwd15w fit on a kenmore model number 41122
Good Morning Kristy, thank you for your question!
Because pedestals are designed specifically for the manufacturer brand appliances, I am unable to guarantee it is compatible for installation with a different brand as the dimensions and other specifications may vary.
Best regards!
Dec 02, 2013 | Frigidaire GLTF2940ES Front Load Washer
Is samsung pedestal model number WE356A5W/XAA compatible with samsung front loader washer wf220anw?
The correct pedestal for the WF220ANW washer is WE357A7W . The WE356A5W is a slightly different size to secure it to the washer (14 2/5 X 27 X 28 7/10 In). The WE357A7W is 27"(W) x 14"(H) x 28.5"(D). The holes for the screws will also not quite line up.
I hope this helps.
Jul 11, 2011 | Washing Machines
Samsung Dryer keeps tripping the circuit breakers
The "professional installer" likely set the pedestal on top of the power cord and damaged it, or the dryer duct has been pinched off causing the dryer to overheat.
Jun 13, 2010 | Samsung DV448AGE Gas Dryer
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
We had the tv mounted on the wall and now want to mount uit back on the pedestal. We have the pedestal but seem to be missing the piece that locks the tv into the pedestal
Hi my name is Roety,
I can help you with your issue ,
The pedestal slides up into the back, and is held by 4 or 6 screws thats all
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 09, 2009 | Samsung LN-S4095D 40 in. LCD HDTV
Samsung pedestals
Howdy,
So we had a similar problem. I actually went to a Sears Outlet here in San Diego where a tech gave me the bolts for free! But......the pedestals are still not compatible. I think Samsung built this discrepancy on purpose, just as other manufacturers do, because it makes them money. No cutting corners and buying previous year's stuff at a discount. BTW, I did verify the incompatibility with Samsung...
Good luck!!
Sep 29, 2008 | Washing Machines
Samsung WE357A0W Logo
29 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
