Mac lap top cannot connect to and cannot get signal from router
I have an ATT wireless device, 2wire 560. My Mac lap top cannot connect and cannot receive signal from the device...should I say I have trouble connecting the lap top to the wireless device..Please help. Thank you
  • 1 more comment
  • Anonymous May 11, 2010
    The wireless device is a router? It probably has an access page in your browser. What have you tried, and how far have you gotten? Please include machine info.
  • M Norwood May 11, 2010
    And 'discoverable'.
    Is Airport on (on your Mac)? Is the ATT wireless device connected to/generating a network? I presume they are both on and powered up...
  • niicole44 May 11, 2010
    Do you have bluetooth? because if you have that or anything like it you must make sure that they are searching for other devices to connect to at the SAME time
    hope it helps
  • 50 Answers
Apple doesn't support any data card. for use your device you have to install windows using bootcamp please rate it
Posted on Aug 12, 2009
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
Cannot connect my dell laptop wirelessly, will connect with a wire and will connect wirelessly at the library. The old 2wire was ok but we replaced it with a new 2wire today. Have spent 3 hours with att...
Since you are able to connect using a hardwired connection and you're able to connect wirelessly at the library, that simply means that your computer and your internet browser are fine. where is your wireless computer and your wireless located? are there any possible wireless devices interfering with the wireless signal like chordless phones, cellphone, TVs, radios, microwave oven? are your walls in your house covered with metal plates coz that would really make the signal deteriorate. the settinngs on your wireless router may also need to be reconfigured and boost up the signal of the wireless router.if only i could remotely access your wireless router, I would really walk you thru on what to check on your wireless router
Jul 07, 2011 | 2wire (1000-000057-000) Modem
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
The wireless light on my 2701HG-B router does not stay lit. It will stay on for a brief time if I unplug or reset. The power, Ethernet, DSL and Internet lights stay on. Any idea what I can do to fix the...
The Wireless light only stays solid on the 2Wire HG-B Gateway when there is something keeping a wireless connection to it. IF there is nothing connected wirelessly, it will not stay on.
Also another note, I had a problem with my MAC and my Windows VISTA 64 BIT Laptop not being able to keep a stable connection with the default wireless username and password.
To get into the 2wire: Open a Internet window Address Bar 192.168.1.254 Home network "At the top of the page" then click on wireless settings "Also at the top of the page" Then you are in the wireless config to change the information.
What i had to do is change the wireless authentication to WPA-PSK and change the wireless password (Use a 10 digit Number as the pass-code, a phone # would be a good suggestion) , what you also need to do is change the name of the network along with the channel of the wireless, it helps if you take it all the way up to 11. Then you should be smooth sailing all the way. :-)
Aug 05, 2009 | 2wire 2700HG-B Router (2700HGB)
I need to expand my att dsl coverage with an range expander but don't know which one to use. I have a 2wire modem but can't get an answer from ATT about which range expander to use or where to get it
Linksys makes a simple range expander you can use. Most expanders do not need to be connected to the network by a data cable. Just put it within range of your main access point or wireless router, and it "bounces" the signals out to remote wireless devices.
Try the Linksys WRE54G ($70-$100)
Jun 16, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
I want to use 2 wire ATT UVerse -- BUT NOT WIRELESS
the 2wire att uverse router, does not broadcast wireless signal if there is no wireless computer connected to its network. regarding the unchecking of the ssid, it will only hide the network name of your router, but technically, if a computer will try to connect to your router, it will still "send" wireless signal to a computer within its range.
you do not have to worry about the wireless signal being sent, if nobody connects to the router via wireless cionnection.
Jan 11, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Stronger Wireless Signal with 2701HGB Router?
Netgear's web site has an excellent tutorial on how to do this. It involves turning off the DHCP on the Netgear, and linking the LAN prots of the two routers. There is no connection to the WAN port of the Netgear.
Here's the link http://kbserver.netgear.com/kb_web_files/n101236.asp
Carl
Jan 02, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting 2wire modem./router to extra linksys router
to get this right you must make sure that the 2wire will be configured to be your gateway which means that the 2wire itself will be connected to the internet then set the linksys to DHCP mode because if you dont it will give you a router behind router error , make sure that the 2wire is properly authenticated and connected to the internet to make sure access the gui by typing gateway.2wire.net on your browser and run system set up wizard
Dec 11, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Att 2wire wireless and dlink
the only thing you need for connecting 360 to wireless is an Internet connection, an 802.11G wireless router, and a wifi adapter that connects to your 360. They have these at walmart or any gaming store. I suggest giving your 2-Wire back to ATT! NOT QUALITY. Especially for gaming.
I myself prefer my box to be hard wired as lag is far less. BUT..for wifi
Get a Linksys Router and XBox brand wifi adapter for 360. Also google xbox connect. Instead of paying for LIVE
James Mac
Aug 03, 2008 | 2wire (1000-400108-001) Router
Computers & Internet Logo
202 people viewed this question
David Payne
David Payne
