Question about Motorola Mobility RAZR V3
Flashing verizon wireless screen
Hi, I did some combination of charging my phone, turning it on/off while it was charging, and removing the charger. In any case, my phone doesn't work anymore. When I turn it on, all I see is the Verizon screen flashing over and over again until the phone finally turns off by itself. Thank in advance for your help!
    Brigadier General:
  • 7,752 Answers
YOU need to take the phone and ahve the firmware reflash on the phone.
Posted on Apr 15, 2008
SOURCE:
When i turn it on and it gets to the screen where it says verizon wireless it just keeps flashing verizon wireless over and over.
hi,well on the droide,you can try this first,,power off the phone..then remove your sd card and sim if aplicable..
then push and hold the camara button,and then push and hold the power button,in a few seconds youll see the boot screen come up..
it will give you the option to restore the phone or boot the phone.
o restore ,or down to boot,try the boot first because the restore will cause you to lose your data.hopefully you have backed your contacts up..if just doing the boot dosnt work,follow these steps again to do the factory restre..If that dosnt work contact me here and ill
Oct 05, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Samsung Intensity Wont turn on.
More often then not its the battery even tho the battery is fully charged as it may seem. The rel test is get a new battery not your friends battery tho but a new one put it in there and let it charge. If that doe not work then the phone's logic board has been effected and it may or might not be worth reviving. But check the battery first.
Please do be considerate and leave ratings and feedback for all experts involved in helping you out today, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 26, 2010 | Motorola Mobility Boost i415 Cellular...
Verizon Razr V3 with locked screen. Verizon
yes ,down load p2k or another flashing utility,then flash your phone
Mar 11, 2010 | Motorola Mobility RAZR V3
My phone won't charge or turn on. I plugged it into the usb drive, and it tried to sync to the computer, and i remembered i have to turn it off before it would charge and not try to sync to the computer. I...
try to get a new charger or battery if that does not work then i suggest a new battery....... of there is no luck then ask the verizon people... if they tell you to get a new phone then throw a fit and that (most of the time) works :)_
Dec 24, 2009 | LG enV3 VX9200 Cell Phone
When I turn on my phone Verizon Wireless logo pops up and stays
Try taking it to a Verizon Wireless store for troubleshooting. This problem appears to be more than just the battery, as fully charging it did not help.
Jun 30, 2009 | LG VENUS Cellular Phone
LG Voyager won't reboot
Interesting, normally the screen only appears with water damage, which I am sure Verizons customer service has continued to tell you that is the cause without thinking the customer might not know for themselves, The only way to fix this is to got to a Verizon Wireless store and ask them to do what is called a software flash, now it may delete all your information on your device but at least it will work, if you need any more help with this let me know.
Jan 02, 2009 | LG VOYAGER VX10000 Cellular Phone
Won't Turn On/Charge
hi , i know a friend have one like that, same probleme he have to bring back to make it fix by the compagny,, only help can give you Yvon chow !!!
Jan 02, 2009 | LG CHOCOLATE VX8500 Cellular Phone
The Blink Of Death!
well, the cause is definately a software issue...what caused it is hard to say. could be physical or moisture damage, but if u are certain that is not the issue, the phone can be replaced under the warranty if u have had it less than a year, or if u have the extended warranty. if it is damaged or out of warranty, you can use ur insurance, if you have it.
Jul 04, 2008 | LG enV VX9900 Cellular Phone
Won't turn on!
Had the same problem. Itook it back to verizon and they exchanged it for a new one
Oct 26, 2007 | LG VX5300 Cellular Phone
Motorola Mobility RAZR V3 Logo
113 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
