Question about Toro Power Clear 621 ZE 21 163cc Single Stage Snow Blower E-Start
Float stuck on huayi carb
Gas is getting to the carburetor but there is no gas in the bowl
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
Usually not the float. there is a needle attached to the float that slides up a small hole and against a rubber seat. the seat over time becomes sticky and sticks the needle up and in place blocking the main fuel entrance. you can pick up a rebuild kit from you local small engine shop. you will need the 5 digit model number located on a sticker by the wheel axle....
Posted on Feb 08, 2013
Gas leaking from the carburators
Hi, Anonymous and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.motorcycleforum.com/59-motorcycle-repair/96188-carb-leaking-gas.html
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
Gas leaking from carb air filter area think have stuck float motorcycles
Carbs leaking Here is how to fix it
Leaking gas from float bowl really need some help
Mar 15, 2017 | GAS Motorcycles
I cleaned the bottom bowls of the carb on my 78 650 and the first carb on the right hand side the gas is running out of the bottom nipple.
Hi, Jeremy and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
My carb leaks fuel out of the overflow hose at the bottom of my carb
Nov 21, 2016 | Motorcycles
I have a toro z150 zero turn lawnmower.. I can put gas in the carb and it will fire but will shut back off as soon as its burnt.. I took a air hose to all of the lines and getting gas past filter.
That is not a simple answer, You would need to continue the cleaning into the carburetor. Make sure your float and needle valve are not stuck. pull the bowl off the carb to see if any gas is in the bowl. if not the chances are that the float is stuck.
May 05, 2016 | Toro Garden
Why won't my Honda 11 HP GX340 keep running.
The diaphram in the carburetor may have a hole in it
Feb 25, 2015 | Honda Garden
Why is my air filter on lawn mower saturated with gas?
Probably your Carburetor float seal is leaking inside. Have someone check your Carb.
May 28, 2014 | Toro Lawn Mower With Toro Power Tools
Carburetor not getting gas to go threw it
Chances are the float needle is stuck closed. Remove the float bowl and spray carb cleaner at the float pin while gently lifting the float then releasing the float to drop freely. Do this several times until the gas starts to flow when the float drops downward. Check also that the gas is turned on and gas is in the tank. tombones49_12.gif
Mar 23, 2011 | 2005 Honda CRF 450 R
Riding lawn mower keeps flooding
It sounds like the inlet needle seat is not closing all the way,allowing fuel to overfill the carburetor.The inlet needle seat may have dirt in it.You will have to remove the carburetor bowl and check for dirt or debris in bowl,if so remove the float assembly and check for a peice of dirt between the inlet needle and seat.If there is none you may have to replace the carburetor or rebuild it with a carburetor kit.You should also chang the engine oil because the overfilled carburetor drains to the crankcase,filling it with fuel,check the oil level and see if it is high,that would indicate fuel is in the oil.Hope this helps
Jul 28, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Went to reserve fuel - then motor backfiring and loss of power -
Condensation in the gas tank collects at the fuel petcock. Get enough water in there and it gets into the carbs. ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetors. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb.
Put the carb back together and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Jun 18, 2009 | 2004 Honda Shadow 400
I am not getting fuel to the carb. I have taken bolt out of bottom of bowl and there is no fuel coming out. I am getting gas at the end of gas line that is hooked to carb. Any advice?
Sounds like needle is stuck. Remove the bowl and see if float is hanging down or staying level. Needle is at top of float. There is a pin holding float to carburetor. Remove the float before trying to dislodge the needle.
May 18, 2009 | Garden
Gas runs out of from carburetor
if you suspect the float is stuck, grab a screwdriver and tap the carb float bowl with the handle. you should be able to see this from the bottom of the tank. hopefully this will unstick the float.
if it doesn't, then it will require removing the carb and taking the float bowl off and seeing if the float is adjusted properly.
Mar 18, 2009 | Yamaha Royal Star Venture Motorcycles
Toro Power Clear 621 ZE 21 163cc Single Stage Snow Blower E-Start Logo
564 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
