Question about Danby DPAC12030 Air Conditioner
Cuts in and out
Danby 12,000 btu will not cool below 75 degrees, keeps cutting out
  • 883 Answers
Sounds like very low on freon which also keeps the motor running cooler...suggest a refill because of its large btu capacity, but expensive maybe...get quotes.
Posted on Jul 14, 2007
SOURCE:
How can I tell whether my portable AC unit is low on freon gas or if the compressor is bad?
You can tell a compressor is running by measuring amp draw but you can check return air temp vs supply air temp. 15 degrees should be minimum temp split.
Jul 01, 2018 | Danby Heating & Cooling
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
Hi, I have a Daikin Model FTXS35D with RXS 35D 3VNB outdoor unit. Until this year it was excellent, now does not cool as before. Have cleaned filters etc. Could it be a sensor problem. When I...
Your unit should cool 15 to 20 degrees. 75 return air temp should be below 60 degree supply air temp. If you are not in this range you likely have a refrigerant problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 14, 2017 | Cfm Daikin R410a Split System Air...
Need a copy of the manual
Here's a link to the Owner's Manual for your Model Danby Portable Air Conditioner.
Your model has been discontinued, so download and print this manual for future reference. Making sure to keep it in a save, accessible place.
http://www.danby.ca/cms/uploads/products/en_manual/DPAC%20%209030%20and%2012030%20manual.pdf
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Danby DPAC12031 Silhouette 12,000 BTU...
My air conditioner will kick on but will stay on and not
The thermostat is not functional, therefore its not cutting off the compressor once the room air gets cooled to the temp setting of the thermostat, also the refrigerant gas may have leaked out some but not the entire refrigerant gas(freon, CF4, etc.), keeping the compressor running contentiously to come down to the set temp..............sodeep
Aug 20, 2009 | Carrier 38CKC042 Air Conditioner
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
Danby 12,000 btu a/c installation
they are a pain in the you know what the best way i have found is to cut a peice of wood to fit the window perfectly then the 4" hole into that to make a good fit the flimsy plastic thing they give you is not very strong.
May 20, 2008 | Danby DPAC8399 Air Conditioner
Cuts in and out
I suspect a bad compressor run capacitor. Take the unit to a service facility & have the capacitor & overload protector replaced. The overload will be weakened by the repeated cycling.
Jul 14, 2007 | Danby DPAC8020 Air Conditioner
Danby DPAC12030 Air Conditioner Logo
254 people viewed this question
Top Danby Heating & Cooling Experts
Dennis Boxerman
mintvl
Level 1 Expert
Bill Long
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
