Question about Konica Minolta Copier Toner EP6001 CS Pro EP801550,000 Page Yield 8935-602
I have a Minolta CSPro 3050.. legal paper drawer won't close..and it won't copy
When powered up, it states open the drawer - indicates that there is a paper jam..but I can't get the legal paper drawer to remain closed.. I can close it all the way but it is like a latch is not closing
  • lrbellmor742
    lrbellmor742 Jan 18, 2013
    Clarify.. legal drawer won't close. The troubleshooting response on the display says open panel to get instructions for clearing jams.. I don't have a jam.. I have a paper drawer that won't close and appears to be the cause that the system looks for a jam... don't know.. I can close the drawer all the way , hold it in, recycle the power up and still get the same response
  • lrbellmor742
    letter drawer will not open. No response when pushing on the open drawer button even with legal drawer is held in.. the paper drawer opens when button pushed. The duplexer drawer opens .. no problem there.. it seems the problem is between the letter drawer and the legal drawer
  • Konica Minolta Master
  • 1,294 Answers
To the rear cover located one hole before waste toner box.Introduction one long screwdriver and push the unlock button.
Posted on Jan 30, 2013
3 Suggested Answers
  • 345 Answers
SOURCE: Our office's Konica Minolta Bizhub C360 is always
This model has a tendency to fold corners. Have the tech. check the input guide to the fuser unit and also to check the door on the right hand side above the bypass tray. Its a fairly common issue. Also have them search konica-minolta's website for other techs having this problem. Good Luck !
Posted on Aug 11, 2011
  • 118 Answers
SOURCE: Misfeed detected. I have opened everything I know
there is a piece of paper in the area between the tray 1 and the door. sometimes you can use cardstock to push the paper out. try it
Posted on Oct 21, 2011
I have Minolta Copier CSPRO 4000; it has error Code: c0372 please help
The bottom paper draw and duplex section have each a plug you plug into the copier in the rear. you mite want to check them for loose connections or the connectors themselves the code is stating that copier can not talk with bottom draws or the duplex section which makes your second side on a single paper. Open close front door to reset and could reset the machine power it off disconnect bottom draws and duplexer then just use the copier that way.
Jan 10, 2013 | Minolta EP4000/5000 CS/PRO Copier
Lexmark officeedge pro550 print drawer won't close with legal size paper in it
That's normal. If you extended the tray to accommodate legal-size paper, then the tray sticks out from the front of the printer when inserted.
Aug 24, 2012 | Lexmark OfficeEdge Pro5500 - multifunction...
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
What code C0200 mean for minolta ep4000 cspro
Below the drum is an assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code.
Jul 06, 2011 | Minolta Office Equipment & Supplies
I have a Minolta CSPro 4000, and I am getting the following errors on the display screen code 0d50
C0d50 means you have a duplex error. This would be coming from the duplex drawer just under the main front door. You must open then close the duplex drawer to reset this code. It can not be reset by opening/closing the front door as with most other codes. Most of the time the c0d50 code will reset by opening/closing the duplex drawer. If not you will need service on the drawer as there is a drive or sensor problem in the drawer. The guides in this drawer have to jog in and out for different paper sizes and orientations. This code is usually causes by a failure of the guides to move properly.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 29, 2010 | Minolta EP4000/5000 CS/PRO Copier
MINOLTA CSPRO EP1083 PHOTOCOPIER NOT WORKING DISPLAYS "COF 30 " AND STOPS COPYING
Open the paper drawer and switch the green button which is located towards the back of the paper drawer on your left. My copier does this everytime I add paper.
Oct 11, 2010 | Minolta EP1083 CS/PRO Copier
Drawer error
on the diplay panel at the very bottom of the left hand side do you see a small little symblos (wrench) touch it the panel will go to a different display, then once there open and close the front door. its reset procedure. Next try, Open the front door youshould see a cover with a small screw, or if the cover is off, you will see two buttons, one is trouble reset the other is initialize the one to (try 1st) the left the trouble reset to the right, two draws down worked with minolta never had both draws go, make sure once the draws open check behind them for paper. Open and close front door first off also
Aug 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
EP3050 error code C0040
A C0040 error code indicates a problem with the suction deck fan. It has nothing to do with the paper lift motors.
The fan is accessed by removing the rear cover of the copier. It is right in the center. These are readily available (p/n 9313-1310-61) although they are not cheap (around $200 retail).
Nov 15, 2008 | Minolta Office Equipment & Supplies
Minolta cspro ep2010
Do you have two trays or four trays for the paper? If you have four and the display is showing the bottom door is open... turn the copier off and disconnect the bottom two trays and turn it back on..... Just use the top two paper trays.. Or the problem is that a acturator is broken off the side door, look for any broken pieces of plastic. Also, recheck for any jamed paper left in the copier.Good Luck
Jun 12, 2008 | Office Equipment & Supplies
Konica Minolta Copier Toner EP6001 CS Pro EP801550,000 Page Yield 8935-602 Logo
101 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
