Question about Kenmore 24902 Top Load Washer
Replace solenoid valve on kenmore series 80 washer
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
SOURCE: I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Posted on Jan 22, 2009
  • 59 Answers
SOURCE: fill valve is stuck on my kenmore 80 series
TAKE TWO SCREWS OUT OF THE TOP CONTROL EITHER IN THE FRONT TWO SIDES OR THE BACK THERE ARE TWO GOLD METAL STRAPS POP THOSE OFF UNPLUG THE SWITCH CONNECTED TO CABINET AND THEN CABINET WILL COME OFF WILL BE ABLE TO ACCESS THE WATER VALVE
Posted on Apr 29, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 11, 2009
mgprice
  • 744 Answers
SOURCE: kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Oct 14, 2009
Kenmore 80 series Model 110.28812790 - water leak inside tub
It's quite possible. First see the Sears parts list for your washer with diagrams of all major parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+110.28812790&pathTaken=partSearch
Then see the Whirlpool / Kenmore Service manual for these washers and check the troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Mar 26, 2010 | Kenmore Washing Machines
Kenmore 80 series washer will not fill. replaced
You will have to have an electrical test done. If it's not filling, that means there's no current getting to the fill valve. Have a qualified technician do an electrical test. But also, have him test the timer, too!
Dec 15, 2009 | Kenmore Washing Machines
Kenmore Heavy Duty 80 series with the setting on coldcold no water runs into the washer
it sounds like the cold side solenoid on the water valve has burned out. try switching the hoses around for a test to see what happens. you may have to replace the water inlet valve it comes as a complete unit. as an aside, it is always a good idea to run at least one load of hot wash per month to keep the soap scum from building up in the hoses and under the agitator. hope this helps.
Oct 15, 2009 | Kenmore Washing Machines
Kenmore Series 80 heavy duty has a water flow problem
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are clear of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad solenoid and the water inlet valve assy will need replaced. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 06, 2009 | Washing Machines
Does not fill
Check the solenoids at the water inlet valve for continuity using a multimeter or ohmmeter. A lack of continuity indicates a faulty solenoid.
Hope this helped and best wishes.
Aug 14, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore series 80 washer's cold outlet doesn't work
Hi, It does sound like the inlet valve is bad. If the screen inside the inlet vavle is not plugged, you will most likely need to change the valve. If you will send me a model #. I can tell you how to get to the valve for replacement.
Thanks
Vic
Jul 26, 2009 | Washing Machines
Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
I replaced the lidswitch on a Kenmore 80 series washer. Nothing
Possible bad pressure switch. Turn unit on and jump out 2 wires at a time (3 wires go to it). See if any of your combinations get unit running (one of them will cause water valve to open); if so then that is your problem. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 28, 2008 | Kenmore 24032\24036 Top Load Washer
Hot water wont shut off
solenoid valve is jammed open
replace
Mar 31, 2008 | Kenmore 24902 Top Load Washer
Kenmore 24902 Top Load Washer Logo
43 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
