Question about Philips DCM250/37 MP3 Docking System With Built-In Cd Player
Cd stuck cannot get cd to eject from this system
2 Suggested Answers
  • 11 Answers
SOURCE: cd is stuck and showing that no cd is in unit
This fault can be caused by a second CD having been forced into the drive somehow. Shine a torch into the slot to check. A friend of mine had 3 CDs stuffed into the drive by his toddler! Unfortunately the drive did not survive.
Posted on Sep 11, 2012
A CD is stuck in my bose system How do I get it out?
From an other web site
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Oct 09, 2014 | Bose & Wave& Music System
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
Stuck CD Magazine
You'll have to take the cover off. Look for screws around the back and on the sides. Most likely a cd is wedged in the wrong place. (not fully ejected) and is preventing the magazine from ejecting.
Jan 02, 2014 | Fisher Audio Players & Recorders
Microsystem CD wont eject
I know I've come to this late, but here goes anyway...
When you press eject and the CD starts to come out, but gets stuck when a little bit of the CD is showing, I lightly press down on the CD which 'releases' whatever was catching the CD and the eject completes.
Geoff
Feb 12, 2013 | Boston Acoustics MicroSystem CD High...
What's your problem?Bose wave system cd doesnot eject
Contact the nearest authorised service center for Bose. CD loading mechanism has been struck. You have to open it. It is a skilled work.
Jun 09, 2012 | Bose & Wave& Music System
I have a sony computer, the model where every thing is built in behind the screen. a CD is stuck inside and i cannot remove. anyone have any knowledge on what to do to remove same?
The CD, DVD or BD drive tray may not open when trying to eject a disc. This can occur if there is a mechanical failure, or if there is a disk stuck in the drive.
Please follow the following steps to resolve this issue:
  1. Because some applications can prevent the drive tray from opening, close all open applications.
    NOTE: If the Roxio DirectCD software is running, eject the CD using the Roxio DirectCD software.
  2. Attempt to eject the drive tray using the eject command of the operating system.
  3. Restart the computer to the BIOS by continuously tapping the F2 key on startup and, while in the computer BIOS, press the EJECT button on the computer.
    NOTE: If the drive tray ejects in BIOS, but not in the operating system, reinstall the CD, DVD drive.
Sep 16, 2010 | Sony VAIO VGC-RB40 PC Desktop
CD is stuck and cannot be ejected
mine does the same thing..cd or dvd gets stuck and will not eject or respond. this seems to be a common failure of this model..thoughts?
Apr 22, 2010 | Bose Lifestyle 20 System
Cd is stuck inside how to eject
if there is a tiny hole on front place a paper clip in there it will eject it does on other systems
Apr 16, 2010 | Pioneer CDJ-1000 CD Player
Open/close doesn't work
When you press Eject CD button, do you see CD display blinks as if its preparing to be ejected? If its true then eject switch is working and cd mechanism is stuck, requires service. Also check loading belt in mechanism.
And if unit shows no response on pressing CD Eject button then switch is bad, replace it.
Jun 30, 2009 | Aiwa NSX-A115 Shelf System
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Philips DCM250/37 MP3 Docking System With Built-In Cd Player Logo
    41 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
