LifeCam advanced video settings have a parameter called "BacklightComp ".By default it comes =3.In my setup it is best when =1.After I restart the computer it gets back to 3.Can you tell me where that information is stored and how I can change it?I found a binary key in the registry which is very long and may have all the settings together
1st You download Webcam Driver.
Change and hold LifeCam NX-6000 video driver default settings after restart
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
SOURCE: Microsoft LifeCam NX-6000 and Yahoo messager
you'll need the drivers for that Yahoo IM from your webcam folks. it's a bit persnickity
SOURCE: Microsoft LifeCam VX-6000 won't work with AIM
Try installing Skype. Its free and works best too chat with Family and Friends. After installing use info below.
Normal
0
Web Camera’s have to be
setup on the program they are to be used with.
Just installing the camera on your computer does not set it up to broadcast
on messengers or Skype.
Each program has Options that have to be setup in order for
the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
The camera and audio should function properly. Your friends and Family will now see and
talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up
as follows:
C. Windows Live
Messenger:
NOTE: You audio and
video shoud work. Enjoy.
When done both the Audio and Video will function properly so
you can chat and see family or friends you are connected to.
Hope this helps. Bud
SOURCE: Unable to change settings on Microsoft Lifecam VX-1000
uninstall then redo but make sure no folder in program files afer uninstall
SOURCE: installation microsoft lifecam nx-6000
Normal 0
See section A. Skype in the info below to setup the Audio & Video.
Also send this to your familyand friends so they have there computer setup properly.
Web Camera’s have to besetup on the program they are to be used with. Just installing the camera on your computer does not set it up tobroadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
The camera and audio should function properly. Your friends and Family will now be able tosee and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
Hopethis helps. Bud
SOURCE: Lifecam NX-6000 with Skype
When Skype uses the Lifecam, an icon named "Microsoft LifeCam Dashboard"(it looks like a round blue button) shows up in the System Tray (lower right corner of the desktop). Click the icon to pop up the dashboard.
