Question about AOC E2343F 23 inch LCD Monitor
Was dusting monitor and computer area and now monitor won't come on. Have checked all connections.
    Genius:
  • 1,479 Answers
I've experienced similar problems and the power button gets dust in it and it stops working. Try 'flicking' the power button to see if it clears it, that's what I do.
hold the power button firmly closed then suddenly release it - I use the edge of my nail to hold it closed.
Posted on Jan 19, 2013
I have an lg home cinema and docking station GT462DZ . Sometimes, when i try to dock my ipod touch in it , it says 'check ipod' and it won't play music . It won't work. I always restart my...
It could be that some dust or something has got inside the dock and giving a bad connection. Check both devices for damage to the dock connections.
Feb 15, 2018 | Audio Players & Recorders
I replaced a video card... now the computer won't start at all
did you move any power or data leads around
is the video card a new one that is compatible with your motherboard
check all power and data leads that attach from motherboard to hard drive for secure dust free connections even a loose fan lead connection can cause you problems
if its a 40 pin flat ribbon ide it will be suspect
also check the video card socket for dust and for compatabilty
hope this helps
Jul 27, 2012 | Intel Desktop Board D845GLVA...
Monitor won't awake
Check the connections of monitor with the CPU (big box) and try to switch one it again if its not then there could be the problem of feature tube of that CPU then there you have consult with the technician to fix out.
Jun 01, 2012 | Computers & Internet
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
My monitor won't turn on!
have you tried connecting it to a working pc? did you check if your pc is booting up?
Apr 06, 2012 | LG L206WTY-BF Monitor
Our new hp monitor won't restart after computer is taken off sleep mode the screen will show a partial screen saver but it won't display icons until you turn off monitor and turn back on
is this only your monitor or is it your computer as well
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) Ide/Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Sep 13, 2011 | HP Computers & Internet
My computer won't read the new camera I've got. Even after installing all info from cd. Have tried camera and it works on tv. It won't let recognise the device on problem either. What can I do?
A camera that works connected to a TV without software is not the proper device to connect to a computer. Check again with your packaging and instructions.
Having a camera working on the computer and then porting the video signal to a TV monitor is the preferred arrangement.
Install the software, reboot, then connect a PC camera, it should be recognized and be testable on Skype, etc.
Sep 12, 2011 | Dell Dimension 3100 PC Desktop
No power , computer will not turn on
Hi, IF the system is not turning on any more, try removing the power cable, then press the power button for 10 seconds. then try to power it on again . If it is still not powering up there could be an issue wiht the power supply of the computer. But if it start to turn on, like showing the Sony logo then windows but not going to the desktop. you can try to log on using safemode. you can go there by pressing F8 on the keyboard after turning on the computer. If it still not turning on even on safe mode. there couldbe an issue with the operating system of the computer and needs to be reinstalled.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Aug 20, 2011 | Sony VAIO V2M (VGCV2M) PC Desktop
AOC E2343F 23 inch LCD Monitor Logo
75 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
