Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Ultimate Care II will NOT spin on the last spin but
BUT, If I set it manually at that last spin then it will spin. Why will it spin when I set it but not in the cycle process?
  • 130 Answers
Your timer may be going, that setting may be worn out. also a motor coupling may be the culprit
Posted on Jan 26, 2009
LG TurboDrum DD 8 kg WT R801 machine with LE error. Usually I can override the spasmodic message by manually setting the wash, rinse and spin cycles, but not today. The motor speed indicator is not
You have an intermittent problem with the machine's motor. Have the stator and rotor sections of the machine checked out by a qualified electrician.
Jan 01, 2015 | LG Washing Machines
Washer enters spin cycle but does not advance past the spin cycle
William, do you mean it does not stop after spin? Usually spin is the last cycle. If it stops but does not switch after some time and the settings dial does not move, its a different story.
Aug 19, 2013 | Washing Machines
Water sprays into machine on spin cycle
the machine is programmed to spray water during the initial period of the spin cycle as an added method of removing any remaining suds
that stops then the spin cycle goes into high speed spin for that last few minutes
If the problem is that it continues to spray water until the spin cycle is finished it will be the program board or program controller switch
Oct 15, 2017 | Washing Machines
How do I get my duet to drain and spin only. I do not want to rinse.
I have a Whirlpool Duet, though possibly a different model. I had the same question. I finally figured it out. On p. 14 of the manual, there is a section "To drain the washer manually". This says to select the RINSE/DRAIN & SPIN cycle and deselect the EXTRA RINSE option. In this case it cancels ALL rinsing for the cycle. This is how you get a spin-only cycle! Talk about idiotic, obscure user-interface design and bad manual writing!!! Didn't they think people would want clear instructions how to get a spin-only cycle?
If you have trouble with things being too wet after washing & needing an extra spin, you should try lowering the spin speed when you wash. This is what the BULKY setting does. If you have an unbalanced load, the washer cannot get up to the high spin speed the normal cycle calls for, and it is so dumb that it gives up and gives you a soaking wet load at the end instead.
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My final spin cycle is not working on any wash
TIMER!!! Last cam in your timer has a loose set screw or is broken. Don't try to fix it, it won't last. Buy a timer.
Mar 09, 2010 | Washing Machines
Maytag Neptune topload model fav6800aww. does not spin
Thank you for posting your model number.
Are you taking error codes to the LED display such as dC or uC with fail to complete spin cycle?
Is the wash tub banging the sides of the machine at the start of Spin Cycle?
Will your FAV6800A complete a spin only cycle with no clothes in the wash basket?
If you are going to DIY the repair take a look at this step by step process Clutch Fix Post
Basic mechanical skill set and hand tools are all that is required. I can help you through the process just let me know what direction you want to go.
Links to the FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
If you can give me the first two digits of your serial number of your machine it will be 10 through 17?
Jan 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag FAV6800, Stops at 34 minutes and will not stop, finish or unlock.
Hello AlpineCA,
I believe you are failing in spin cycle but that’s a wag without any error codes to go on.
With no error code it will require a bit more troubleshooting. If you start a Quick Wash cycle with minimal spin/soil settings I believe you will stop at the 21 min mark.
Not sure what wash cycle you are in and Spin/Soil settings for that cycle but I believe this is the spin cycle of that wash cycle (34 min).
I assume the washer did not pump out the water. The FAV6800A/FAV9800A is designed to start in the spin cycle with a fair amount of water in the wash tub so I assume you have water in the wash tub. You can enter Service Mode and turn on the drain pump to pump out the excess water. I’ll attach the process at the end of this post.
Before we do that let’s gather some info for troubleshooting. I want you to do a Spin Only cycle with that wet wash load. Let me know if the Cycle completes. The FAV6800A/FAV9800A machines suffer from chronic clutch malfunctions which will cause failing in Spin Cycle usually with dC/uC unbalance errors. Can you complete a Spin Only cycle?
My standard links for the DIY’er and can you let me know if you want to DIY the fix? Some folks can’t tolerate the down time and if you feel your aren’t qualified then I would recommend a qualified repair service. I’ll work with you until you decide to pull the plug on the DIY process.
Pump out the excess water in the tub when failing in Spin Cycle;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
I’ll check back from time to time for your response. This board will not auto notify by e-mail of your response and most recently won’t let me post pics for troubleshooting support.
If you are going to DIY and we have no error code to the display the next step is to remove the front cover of the machine start up a Spin Only cycle and see if the motor will turn the clutch pulley CCW. Just be careful of the belt and follow safety warnings in the Service Manual…..Rich
If you want to work on this a bit quicker e-mail me at dh1200s@yahoo.com
Dec 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal De
