Flashing start light on nordmende washing machine
Wont start or wash
SOURCE: my tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Posted on Jan 05, 2007
  • 183 Answers
SOURCE: The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Posted on Jul 30, 2007
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
Mark Harmer
  • 8 Answers
SOURCE: Washing machine problem
Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
Posted on Sep 21, 2009
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
The start button keeps blinking, WONT LET ME DO ANYTHING
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
WF-F7061DN washing machine water level lights flashes
Are you overloading the machine? If you run the machine without anything inside and this happens, check the motor or belt.
Jan 14, 2014 | LG Washing Machines
Nordmende dishwasher dfsn60
nordmende dfsn60 error code f9 , the dishwasher is stuck on the 4th cycle but not washing and error code f9 appears how can i fix this
Jan 05, 2014 | Televison & Video
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Hotpoint wma32pr door light keep flashing and no wash
1) test the lid switch for open
2) test the door switch for open too
3) see the diagram attached, any switch faulty can not START the motor.
God bless you
Jun 19, 2012 | Washing Machines
My washing machine wont start up all flashing lights on LED's Basically i click on the start button and all the LED's start flashing continuously. Initially it flashed for about 3 minutes and then i could...
Machine is finding a problem during the initial diagnostucs on startup. Check for damp, condensation on the carbon brushes or worn brushes. Also check for earth leakage.
Dec 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Feb 24, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
462 people viewed this question
Top Washing Machines Experts
