Question about Acer Aspire 7540 7551 7736 7741 7745 Ac Adapter Charger
Acer 7736 wi-fi button disabled and when i push it nothing happens
I can not turn on my wireless. It is disabled and i can not enable
Krenn
  • 59 Answers
SOURCE: Problems with wifi lan configurantion.
hmmm... is the wireless card listed in the device manager at all? even as a yellow question mark?
do you have a USB wifi adapter you can test on this computer?
Posted on Mar 29, 2008
frankzjm
  • 191 Answers
SOURCE: Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
Posted on May 17, 2009
  • 489 Answers
SOURCE: NETWORK IS NOT CONNECING IN wi-fi in our wireless network with WPA2 system. but its detecting the network. should i install any new software to support WPA2.
try to setup again  wireless card's driver  if it doesnt work your wireless car is break down.
have a nice day and sorry for english.
Posted on May 27, 2009
  • 489 Answers
SOURCE: Upgraded Acer 2500 Travelmate with a Wireless card
you can find the driver from here. download and install to use Wi fi
http://support.acer-euro.com/drivers/notebook/tm_2000.html
Posted on May 30, 2009
leecom72
  • 4806 Answers
SOURCE: I have an Acer aspire
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Go to your laptop, right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Posted on Aug 03, 2009
DELL Latitude E6510, wifi button was OFF, now it is not working.Wifi is showing red cross. Please help how t0 turn it ON? I think it is Hardware issue. Can I fix it through Windows? Windows 7
Information Technologies
Share
Enable / Disable an Enterprise Laptop's Wi-Fi
Wi-Fi, short for Wireless Fidelity, is networking technology that allows you to connect to the Internet. If you have a wireless-enabled Latitude computer you can connect to the Internet when in range of an access point called a hotspot.
When not in use your Latitude's wireless card should be disabled. By disabling Wi-Fi, you will receive two benefits:
Start-up times will be much faster.
If the wireless card is ON and you are out of the office (not connected to your normal, wired connection), the laptop will try to use the Wi-Fi network during the login process to run the various start-up scripts, etc. It will eventually time-out (fail). By having the wireless card turned OFF, the start-up process will be much faster.
Computer will not continually search for a wireless network (and waste battery life).
If you are in the office (connected to your normal, wired connection) or in a location where there is no wireless hotspot, you don't need to have the computer waste processing power by looking and looking for a wireless hotspot. By disabling Wi-Fi, you will gain a little more power for your other tasks. In addition, you will maximize your battery operating time by disabling wireless activity.
NOTE: After your Latitude has started up completely, you can ENABLE the wireless card and connect to a wireless hotspot. For example, a wireless router at your home or at a local coffee shop. If you have connected to this hotspot previously, the wireless card should connect automatically for you.
NOTE: Once you have the wireless card enabled, before you shut down the computer, you should again DISABLE the card. The computer will then be ready for the next time you turn it on with wireless turned off.
Enable / Disable with Hardware Switch
The more recent Latitude models have a wireless switch to enable or disable wireless network devices and the
Wi-Fi Catcher Network Locator.
Dell Latitude E6420 and E6520 Series
These laptops have a small switch on the RIGHT side of the keyboard. The switch is toward the front of the laptop. The Wi-Fi Catcherâ„¢ icon will is above the keyboard. You will see a lit radio tower if the wireless switch is enable
Oct 17, 2016 | Dell Latitude E6510 Notebook
Can't get wi-fi connection
There are a number of reasons why you may not get a wi-fi connection:
  1. No connection available
  2. Poor signal strength
  3. Wi-fi on device not turned on
  4. Faulty wi-fi driver in device
  5. Using wrong wi-fi security password
  6. Router has your MAC address blocked
  7. Faulty wi-fi module in device
If you can give specifics on what you have tried and what the results are we may be able to narrow down the possibilities.
Oct 25, 2015 | Computers & Internet
Why don't i have a wireless network adapter showing in my device manager?
Hi, Try reseating the wireless card then restart the computer. If that doesnt work manually reinstall the driver, you should be able to find the drivers on the acer site.
It could be the card itself may need to be replaced. If you know someone with a usb wireless adapter borrow it, install and see what happens.
Since it's not showing in the device manager but shows it is disabled makes me think it's a driver/hardware issue.
Robert
Feb 05, 2013 | Acer Aspire Computers & Internet
I can't turn on my wireless LAN. There is a button at the top of the keyboard of my Acer Aspire 4520 but when I press it, it says "wireless LAN disabled". I have tried everything to turn it...
hi, plz type " ncpa.cpl " in run command, it'll shows the network connections. if the wireless (WI-FI) driver is updated, it'll shows in that screen. just move the cursor to wi-fi connection and right click it. it might have been disabled. if it is disabled plz enable it and switch it on ur WI-FI switch...
thanks & regards Anas K A
Jun 01, 2011 | Acer Aspire 4520-5582 Notebook
HELLO SIR I HAVE ACER ASPIRE 5740 I HAVE PROBLEM WITH FUNCTION KEYS. AND AT THE SAME TIME BLUE TOOTH BUTTON AND WI-FI BUTTONS ALSO NOT WORKING . CAN YOU GIVE SUGGETION TO FIX THESE PROBLEMS RAMU FROM...
Make sure that bluetooth and wifi drivers are installed.
Go to BIOS and check for any options related to wireless and Fn key settings (Like enable/ disable etc).
When Wi-fi button is turned on, LED indicates its status.
Also refer to user manual that can be downloaded from: -
http://laptop.bg/system/pdfs/85/original/QG_ACER_1.0_Eng_AS5740.pdf?1276169137
Hope this helps you! let me know if any clarification is required
CreativeTECH
Nov 12, 2010 | Acer Computers & Internet
I m nt able to locate my wifi switch on my laptop acer aspire4720z. plz help
Your wi-fi switch is located to the top most buttons on your laptop which is the "easy-launch buttons". The first one is WLAN(your wi-fi), second is INTERNET, third EMAIL, fourth BLUETOOTH, and fifth ARCADE.
You may need to setup your wi-fi by pressing the Empowering Key (triangle button inscribed with letter "e").
Hope this helps.
Feb 06, 2010 | Acer Aspire 4720 Notebook
How do i turn on wireless on acer aspire 4810tz
It has a touch panel at the top above the keyboard touch it to turn on also go into the control panel and select wireless devices select wireless you see a wire connection and a wireless connection right click on it select properties and you will see an option to enable or disable enable it an it should come on
Feb 02, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Compaq Evo N610c Wireless Problem!
FN+F2 is given to disable and enable the wi-fi means once you will press it the wifi will turn on and in second attempt it will turn off.
Check in device manager whether it is showing any wireless ethernet controllerand if not then install.
Thanks.
Dec 09, 2009 | HP Compaq Evo Notebook N610c
Problem with on or two network adapter
First make sure that wi fi switch of your laptop is turn on.
Then check that wi fi netowkr adapter driver is installed perfect and enable.
Go to device manager and enable wi fi adapter.
For check device manager right click on my computer icon then click on property then hardware ->device manager.
Then you see all driver list.
Then enable wi fi .
Also right click on my computer places icon then go to proeprty then you can see your network adapter right click on wi fi adapter then click on "view available wi fi networks."
then connect your wi fi .
Let me know if you need more assistance.Thanks.
Oct 01, 2009 | Acer Aspire 4720 Notebook
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Acer Aspire 7540 7551 7736 7741 7745 Ac Adapter Charger Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
