Question about Panasonic BT-LH1700W Monitor
Bt-lh1700we when putting any input format a glitching come over the input source such as many squares in different siizes , what could this problem be ??
    Genius:
  • Panasonic Master
  • 1,479 Answers
The problem is either your graphics card or your monitor. Try a replacement monitor/flat screen tv and if that works, it's your monitor. If that is the same then your graphiocs card may be faulty.
Posted on Jan 19, 2013
My vizio wv42l has red squares all over the screen. Outlines of faces and other outlines mostly.
try a different input source like from a DVD it could be the signal you are receiving
Mar 24, 2016 | Televison & Video
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
Where is the source button on a hitachi CLE-96o control
Click on the image to enlarge it.
Everyting in the RED square is your source buttons.
Depending on which selection you have it on ( Tv / DVD / SAT )
all of the buttons underneith will take you to a different input.
You will need to know which input you have each componet on.
I suspect you are asking about "source" button because thats the one that has your Cable/Dish input. Simply have to look on the back of the monitor/Tv to see which input you have it plugged into.
Jan 07, 2015 | Hitachi Televison & Video
LG HDTV LED
Sounds like you might have a defective unit, or the source that is connected to your tv (cable box, dvd etc) is going out. A lot of times if you have a cable box, glitches, loss of sound and/or color are because of the quality of the input source. Try changing the channel. If the problem is the same on any channel - or on your dvd/xbox, then it is probably a defective tv. You may be able to get it exchanged through LG. Hope this helps! Good luck!
Feb 04, 2012 | LG 42SL9000 42 in. HD-Ready LED TV
I have a lcd tv it comes on bt thers no picture
The first thing to check is to make sure the TV is on the proper input or source. On the remote control for your TV, look for a button that says "Source" or "Input" or "TV/VCR." Press that button and a menu should appear with a list of connections that are on the back of the TV. Go through each one till you get a picture.
Apr 26, 2011 | Televison & Video
Lost arial connection
Have you made sure that the correct 'source' has been selected on your TV? What does the TV show? Does it show, for instance, the menu?
Connect it all up and turn on. Now repeatedly press the button on your tv remote that changes the signal input. This button will be marked as a square or circle with an arrow through it, or will me named source or input. With any luck you should see your digibox.
May 03, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Black square box pops up in the middle of tv screen.
It is most likely related to the Closed Captioning option on your TV. Go into settings and make sure that CC is turned off, or make sure it's set to CC1. What you are probably seeing is the "text" option included in the CC options.
Feb 14, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Sharp Aquos Color Variations
Put the OPC off and check the conection for Pb signal.
Nov 13, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Panasonic BT-LH1700W Monitor Logo
35 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
