Question about Coffee Makers & Espresso Machines
Flashing cup light! Nothing will now work any ideas?
    New Friend:
  • 12 Answers
Check tube for stoppage or maybe a filter plugged. Had that problem on my Keruiq and line was plugged.
Posted on Jan 18, 2013
All my lights are flashing and they don't want to stop mashene is not working
1. Press the auto off and small cup at the same time. Then Immediately release and re-press the small cup three times.
When it works the only light showing will be the descale light.
2. Press the small cup button then auto off button then release small cup and then auto off, when this works the lights on will be the power button light and the descale light.
ALL OF THE ABOVE DURING THE PROCEDURE MUST BEEN DONE FAST OR RAPIDLY.
3. When both of the above lights are on,(power and descale), unplug for about 3 to 5 seconds... and plug back in. The brewer should come to life and work normally.
Below is the address and Phone number to Keurig warranty service.
Keurig, Incorporated
101 Edgewater Drive
Wakefield, MA 01880
1-866-901-BREW (2739)
Nov 12, 2014 | Keurig B40 Single Cup Home Brewing System...
Why are lights flashing but machine not working?
It can be a number of things. The buttons need cleaning, a bad solder joint or broken wire, a faulty IC on the control circuit board, the circuit board with the buttons could be loose and not making correct contact, etc.
Only way to know is take it apart. You will need a good flashlight and a long straight screwdriver to get to some of the clips. It is NOT an easy task. Look for tutorials on youtube, etc.
May 06, 2014 | Keurig Elite B40 Coffee Maker
All light flashing in my tassimo coffee machine noise as it will start but do not start'
Check the owner's manual and see if there is a reset button. If not then make sure that the cup that holds the grounds is fitting secu rely, If it's not in just right it will not allow the machine to start. These are simple ideas that you've probably tried but I hope they help.
Keith1562
Feb 28, 2013 | Coffee Makers & Espresso Machines
Small cup, add water, heating lights keep flashing after brew
I had this problem too.
I just pressed the small brew button; it pulled some water from the reservoir and heated it but nothing came out. Then I opened and closed the top cop thing and both the cup sizes were flashing and it worked like normal again.
Oct 16, 2011 | Keurig Elite B40 Coffee Maker
Saeco Magic Delexe water light flashing
The brew unit is blocked, check the shower screen under the red o-ring.
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Tefal Quick Cup
ALERT :- Tefal Quick Cup can TURN IT SELF ON. Tefal know about this but it is a potential fire hazard. Mine turned itself on and dispensed the water reservoir over my kitchen. Dread to think if I had been out shopping what could have happened. Tefal know about this problem but are not doing anything to advertise the fault!!
Jan 19, 2009 | Kitchen Appliances - Others
Brand New Nespresso Essenza just stopped working..
If you just bought it you should return it immediately and try another.
Dec 24, 2008 | Nespresso Aeroccino Automatic Milk Frother
Keeps flashing 12:00
I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Flashing lights
the printer when i on the swich the flashing light is on but can't work the printer
Feb 24, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Coffee Makers & Espresso Machines Logo
187 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
