White flakes on screen - Computers & Internet
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 101 Answers
If you see White or Blue specks that don't change no matter what you have on the screen they are dead pixels. Assuming the screen is clean and free of dust. There isn't anything you can do about dead pixels except have the screen replaced.
Posted on Jan 18, 2013
Waht causes black flakes on clothes when washing?
Hi, it sounds like you have to buy one of the inside washing machine cleaners its a liquid that you put in the washer and let it run its cycle to flush clean the interior of the unit.
Jan 23, 2016 | Samsung 4.8 Cu. Ft. 13-cycle...
Chip going bad
If they are white dots that is the OPTICAL LIGHT ENGINE, check all inputs to see if issue the same and you can POST a photo here which might help.
Dec 16, 2012 | Toshiba 62HM95 62" DLP HDTV
Flakes of lcd white screen
your phone hangs.remove the sd card and then dial *#7780# ,it will ask for security key type 12345 then your phone will be restored to original settings.still if it dont work then replace it! remember to format your memory before you insert it yo the phone again!
Mar 31, 2012 | Nokia N70 Cellular Phone
I have a white powdery substance coming out of the steam vents of my Rowenta iron. How do I get rid of this stuff?
The iron has white flakes coming from the steam vents.
The white flakes can be caused by calcium or other minerals in the tap water. To solve this problem, switch to bottled spring water. Once the water is changed it may take several uses before your iron adjusts to the new mixture and the issue is corrected.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Rowenta Vacuums
I have a kitchenaid refrigerator (Model KSRS25ILBL02). The water from the dispenser has some tiny white flakes. I though it's the water reservoir (100' coil tubing) problem. But after I took the...
have you ever changed the water filter that's in the front bottom sticking through the kickplate?part number 4396508 and it's around 45 to 50 dollars
Apr 13, 2011 | KitchenAid KSCS25FKSS Side by Side...
My scrren goin white
THERE IS 2 SOLUTION I RECOMEND,FIRST CHANGE THE FLAKES OR RIBBON & TRY TO REPROGRAM..CELLPHONE TECH.IS NECESSARY!!!
Mar 26, 2010 | Motorola Mobility KRZR K1 Cellular Phone
Our Whirlpool Refrig GD25DFXFW02 is working fine our problem is the ice maker , the cubes contain white flakes, is there a coating on the ice maker that could be chipping off> We have changed the filter...
The inside coating has come off the inside of the ice maker . The white " flakes " is calcium deposits , sticking to the exposed cast metal , inside the ice maker , and sticking to the cubes , after water freezing in the mold . You need to replace the ice maker .
Nov 02, 2009 | Whirlpool ED2FHEXN Side by Side...
My ice maker produces ice with white flakes in it, and slowly.
If you also get the flakes with the water from the water dispenser it could be the water chiller reservoir behind the crisper in the fridge. If it's just the ice maker the non stick surface in the ice mold may be coming loose.
Oct 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
New Mr. Coffee Espresso machine producing white gunk
Hello aura20,
I bought one this week and had the same problem. I used vinegar and rinsed thoroughly and yet the whit flakes remained. I did some research and found that high end espresso makers often have very fine screens that catch minerals and grounds and so on. This Mister Coffee espresso maker has only a metal basket with tiny holes so it's not really filtering anything. Moreover the metal is treated aluminum, so it scales naturally. Also, if your water is hard like mine that just makes things worse. I just tore off a piece of paper towel only big enough to line the bottom of the filter basket and not come up around the edges. Then I put a drop of water on the paper towel and pressed the paper towel against the filter basket so I could see the little holes through the paper towel. Then I rinsed the machine again and the white flakes were completely gone from the water and the paper towel had collected it instead. I did the same thing with a new piece of paper towel and I added coffee, I did not add the maximum amount of coffee and I did not tamp the coffee. The product was smooth and creamy as it came out of the machine very slowly. But it tasted great and it was strong and clean. Upon removing the basket I found hard dry grounds stuck to the basket and paper towel. I had to use a spoon and running water to dig all of it out. It's not as good as professional espresso makers, but it'll do for a quick shot. I hope that helps.
Mar 04, 2009 | Mr. Coffee ECM20 Espresso Machine
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
