Question about Frigidaire Affinity ATF7000E Front Load Washer
Front door seal installion - Frigidaire Affinity ATF7000E Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hi Bill Osborn - I am happy to assist you. First, I will need your model number to better address the issue at hand. What exactly is your concern or issue the unit is experiencing? Is the door not sealing properly?
Posted on Jan 22, 2013
How do I replace the rubber door seal on my beko wmb71642w?
This video will show you in detail how to replace the door seal gasket and fit the new one properly to beko wmb71642w washing machine How to Replace Beko washing Machine Door Seal
Oct 17, 2013 | Beko Genuine Washing Machine Door Gasket...
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Jun 14, 2010 | GE WSXH208A Front Load Washer
Rubber Seal leaks
You have to replace the whole door seal.It can be done through the port hole,difficult but achievable or you can strip the front of the appliance off and do the inner part easier.
Unplug the appliance.
Open the door and take the seal retaining ring out of the door seal.
Peel the door seal off the front panel and fold it inside.
Take the seal retaining ring/spring out of the tub side of the seal.
Pull the seal off and take it out of the appliance.
Fit the new seal to the tub,look at the seal and tub for matching arrow marks to help align it.
Fit the retaining ring/spring into the groove in the seal and over the lip of the tub.
Fit the seal to the front panel and then fit the retaining ring into the seal.
Restore the power to the appliance and leak test it.
If you find you can't get the seal on.
Take the top off the appliance.
Take the dispenser out.
Take out the screws revealed.
Take out the screws holding the door lock.
Take off the plastic cover below the door and remove the screws revealed.
Take the front panel off.
If the panel won't come down and off there will be a hidden screw that requires the facia panel to be removed.It's snap together plastic,just release the catches and carefully remove the facia.
Take the screw out, take the panel off.
Fit the inner part of the seal to the tub.
Reassemble the front of the appliance.
Fit the seal to the front.
Leak test the appliance.
Apr 06, 2010 | EuroTech EWF150 Front Load Washer
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Front seal leaking in my bosch exxcel 1200
This video will show you how to change a door seal on this bosch bosch exxcel 1200
Mar 28, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Hotpoint aqurious leaking at front underneath,concrete block wet at front towards door,alot of water coming out,any ideas thanks.david
Carefully check the door seal for any sign of a hole or tear in the seal.
Or it could be leaking from the drum front or the drum front seal, this is another seal , not the door seal., you cannot see this without removing the front panel.
Feb 22, 2010 | Hotpoint Aquarius WD63 Front Load...
Solution for washing machine
  1. remove top cover.
  2. Remove soap dispenser draw.
  3. unscrew the screws securing the the soap dispenser to front console.
  4. Pull timer dial off, noting position of symbols.
  5. slide console panel to right, and lift up out of way of front panel.
  6. Undo 3 screws securing top of front panel.
  7. undo 2 screws securing door interlock to front of panel.
  8. Remove plastic clip securing door seal to front of panel.
  9. remove wire clamp band round front of door seal.
  10. Undo 3 screws at bottom of front panel securing it to cabinet .
  11. remove front panel.
  12. Unscrew thye top wire clamp band securing the seal to drum front.
  13. remove door seal.
  14. Fit new door seal, making sure the drainage holes are at the bottom dead center.
  15. reassemble in reverse order.
  16. Please rate my solution.
  17. Thanks.
Nov 06, 2009 | Washing Machines
How do you replace the door seal on a Bosch Nexxt front load washer?
Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
Refit the seal round the front of the cabinet,and refit clamp at front.
Plz rate this solution.
Thanks.
Dec 19, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Oil leaks
after a period of driveing you have to get oil pan re tighting some times improper installion can keep it leaking also.
Jul 09, 2008 | 1999 Cadillac DeVille
Parts
You could buy a no name door seal gasket from any dishwasher parts supplier but you will loose your warranty with Miele. And extended warranties reach up to 6 years if you bought it from a factory authorzed dealer with a factory authorized installion! Call Miele direct. Miele's number is 1-800-843-7231
If you would rather call your local Miele dealer, they'll be more than happy to do help you!
Oct 13, 2007 | Miele 23 in. Novotronic G841 Built-In...
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
