Question about Kolcraft Travelin Tot 2 In 1 Playard
One of the sides won't lock on the kolcraft travel playpen
All three sides lock but one dosen't is it broke?
Top short rail won't collapse
Here is a link to the instruction manual for the Pet Pen. i hope it helps you to work out the problem. If that still doesnt' help, you should go back to the place that you bought it and ask them for help
http://www.petgearinc.com/Instructions/33/Product%20Series-PG4200%20PG4400.pdf
Oct 08, 2012 | PetGear Home N Go Pet Pen - Large
Where can I buy really large size pet playpens without having to spend a fortune? I have 4 puppies so I need a lot of space.
there are some really huge pet playpens out there. You just need to figure out if you need it to fold down for travelling etc. Here is a link to the crazysales website that seems to have some good playpens for sale. http://www.crazysales.com.au/bargains/pet-playpen
Aug 16, 2012 | Pets - Others
Can I get a travel pet playpen for my cat? I need to be able to fold it up so it fits in the car.
Yes you can. They make travel pet playpens that look similar to kid travelcots. Here's a link to the 'hayneedle' site that sells some really good quality travel pet playpens http://www.hayneedle.com/sale/cobaltbluelargepetplaypen.cfm?source=nextag_hayneedle&mr:referralID=f6eaa29e-e764-11e1-b779-001b2166c62d
Where can I buy a portable, used doggie playpen?
I found two great used travel playpens on eBay. Check them out here:http://www.ebay.com/itm/Dog-Playpen-/140753791332?pt=LH_DefaultDomain_0&hash=item20c5946964http://www.ebay.com/itm/PRE-OWNED-2-Door-Soft-Playpen-Dog-Crate-Cage-Kennel-MEDIUM-45-x45-x24-H-/170833661976?pt=LH_DefaultDomain_0&hash=item27c67ad018
May 15, 2012 | Pets - Others
How to unfold a safety first playpen
Most all of the newer playpens called Pack N Plays use a bottom-center
safety device. You must lift up the bottom of the playpen, usually a tab or twist handle. Either lift or twist and lift to be able to drop or raise the sides. YOU CANNOT RAISE OR LOWER THE SIDES UNLESS YOU LIFT THE SAFETY UP. Dont man-handle the sides. Slamming them up or down will break them. Sometimes it helps to lift the side releases before pressing the releases thet are inside the cloth. Basically the floor of the playpen has to be sticking up to allow the sides to raise or lower and lock.
Feb 12, 2012 | Baby Gear
91 5.0 LX, ran fine yesterday but hesitated when pulling into the garage. Next morning it would crank over rapidly but won't fire. dosen't seem to be getting spark. Any ideas? Thank You.
I would check the timing belt. If it is hard to access, then pull the distributor cap or valve cover. If nothing moves as you crank it. Your belt broke.
Sep 04, 2011 | 1991 Ford Mustang
How do you lock an Avalon on the move series playpen? Where do I get instructions?
  • These playpens have a safety feature.
  1. First thing is to make sure the center of the playpen is up in the air.
  2. First lock the short side rails. They will click into place.
  3. Now lift up and lock the long set of rails.
  4. Now you want to push the center piece (floor) down all the way.
  5. Now your playpen is set up.
  6. When you go to put it up you will pull the floor up first and then release the side rails.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 17, 2011 | Baby Gear
Trying to put together a Foundations playpen but sides will not
The "trick" with the collapsing the foundations playpen is to step on the middle ring while pulling up on the "quick release latch in the middle of the long sides first, then the short sides.
Works every time!
May 15, 2010 | Baby Gear
Putting up and taking down of Graco Avalon playpen
If you take the mattress pad out and collapse the base, you can then lock the sides. I was in the same boat as you. Very frustrating. Hope this helps.
Dec 12, 2008 | Baby Gear
Kolcraft Travelin Tot 2 In 1 Playard Logo
163 people viewed this question
Top Kolcraft Baby Gear Experts
Timothy Shotwell
Timothy Shotwell
Level 1 Expert
Bill Boyd
Are you a Kolcraft Baby Gear Expert? Answer questions, earn points and help others
