Question about KEIO PS2 Optical Scroll Mouse
I cant get any mouse to work on my dell laptop.
When plugged into usb port no mouse will work .did have a mouse a while back that did work then stopped working.nothing wrong with usb ports as other things work through them.how do i install the new mouse on laptop.its a wired optical mouse model no am-3055u can you please advise
    Novelist:
  • 126 Answers
See the very first thing is that what u can try is that try and connect the same mouse that u had and that had worked and if works then the prob is with the mouse that u have right now and if that also doesnt work then the usb port on the laptop has gone bad and u need to replace the motherboard of the computer but before replacing the motherboard try and connect some other usb device on the same usb port.........
Posted on Jan 25, 2009
Several times each day my mouse on my laptop (Dell Lattitude E5510) becomes unresponsive. I can then use the touch pad to restore my control or the mouse works if I switch USB ports. It doesn't se
Some mouses stop responding if you do not use it for a few minutes. This is usually a battery saving feature. Usually all you got to do is use the scroll button to reactivate the mouse by scrolling up or down. This will bring the mouse back to life. When you change the ports you are actually doing the same thing (reactivating). Also check whether battery needs changing.
Mar 01, 2012 | Computers & Internet
Dell 6420 laptop not recognizing USB ports while on docking station
Hello Jackie.
2 of youre USBs are USB 3. so you need to install the right drivers for USB 3.
Also you should check youre BIOS settings, if there is an option to enable "XHCI" support so enable it. (USB 3 needs this to work ).
regards Gue.
Apr 21, 2017 | Microsoft Computers & Internet
Dear Sir, Have Dell laptop Inspiron 1525 with Xp loaded....but external mouse is not working with my system but the USB port are working, Sir i need your assistant how do i do with it. Pls HELP...
You will uninstall all the usb universal root hub , and to do follow all the steep.
R- click on My com>Properties>Hardware >Device manager>Scrol the mouse down for select usbhub controller . Now you will uninstall all the usb and restart the raptop again.
If your problem will same ,change the usb MOUSE .
Think it is defected.
Hope it will help you.
Dec 31, 2010 | Computers & Internet
My Dell Latitude D400 laptop's USB ports stopped working. They used to work fine, now they don't recognize anything (card readers, mouse, camera, etc.) I removed the USB port drivers and reinstalled. It...
USB port is corrupt...if all that you said is what is happening then the best is to
buy a keyboard to USB port convertor....
refer this image....Ebay has it for about 1$
May 10, 2010 | Dell Latitude D400 Notebook
Dell mouse, Toshiba window 7 laptop need driver to make it work
if you plug it in to usb port go to control panel check mouse setting should work
May 02, 2010 | Dell U0636 Mouse
When working on my computer Optiplex 745 Windows XP professional the optical mouse becomes non operative (no response, no red light). If I shut down and restart the computer it is fine.
Make sure the HDD jumper is set to master and see whether it helps.
If not the HDD is not recognised by the PC. Also make sure the connections between the HDD and mother board.
· Try a different IDE cable
· Try a different HDD an
All the best!
Jul 06, 2009 | Dell U0636 Mouse
Arrow wont move
Dear Fayereid01,
You said "I have a dell computer and when I turn it on to the desktop the arrow wont move to go any further its a desktop with a IBM keyboard"
Make sure that the mouse is plugged into the the correct port. If the mouse you are using is a USB mouse then try other USB ports. If it is another type of mouse that uses a different plug, then try all the ports on your computer that it fits into until it works. It sounds unprofessional but it should work.
If none of this works then put in the CD that should of come with you mouse and install the drivers for your mouse. If you cant find the disc for your mouse then go online to the manufacturers website and you should be able to download the drivers there.
If i was helpful please rate me positively
Jul 02, 2009 | Dell desktop and monitor -Inspiron...
HELLO
is your mouse and keyboard plugged into a PS2 connector http://en.wikipedia.org/wiki/Image:Ps-2-ports.jpg
look inside of your case and see if any capacitors are buldging on your motherboard the tops of the capacitors should be level/flat if they're ok, sounds like they are going, look for brown rusty color also around tops of capacitors, might be your outputs are going. If you have your mouse and keyboard plugged into ps2 ports try a USB Mouse and keyboard, borrow one first or buy a usb laser mouse for $12 worth a try even if your ps2 ports are blown, use the usb ports for mouse/keys ;)
Jan 10, 2008 | Dell Dimension 4600 PC Desktop
KEIO PS2 Optical Scroll Mouse Logo
717 people viewed this question
Top KEIO Computers & Internet Experts
David Payne
David Payne
Are you a KEIO Computer and Internet Expert? Answer questions, earn points and help others
