Question about Panasonic Lands Phones
Panasonic cordless phone and directv
When I run a cable from the wall jack to my Directv receiver (HR34), the tv displays the caller ID, but the phone does not ring. However, the phone receives the call and the caller can leave a message on its answering device mode. The failure to ring only occurs when a line is run from the jack to the Directv receiver. My phone service is Windstream and they furnish the modem. The line from the wall jack plugs into a splitter with one jack called "phone" and the other "ASDL" - the line to the Directv receiver is from the "phone" on the splitter.
  • Robert Charles Jan 20, 2013
    It's the usual Windstream blames Directv and vice versa.
  • 193 Answers
SOURCE: Callers can't hear me but I can hear them
change the channels on the phone and reboot it
Posted on Oct 09, 2007
SOURCE: Caller ID Problem on the GE2811 Twin cordless phone system
Still have not been able to solve the problem of having inconsistent caller id display when the telephone rings
Posted on Mar 24, 2008
  • 95 Answers
SOURCE: need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Posted on Mar 29, 2009
  • 56 Answers
SOURCE: RCA DVR-40 Directv receiver will not make a call to Directv
i believe you have to slow the modem speed down. contact directv 800-531-5000 on instructions how to slow the modem speed. tell them you are getting "service not answering" hope this helps!
Posted on Apr 05, 2009
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Posted on May 11, 2009
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
Rc65x remote won't work with hr34-700 receiver
Try hold mute and select at the same time once you see a green liggt blinks twice under the directv logo press 00001 or 00002
Mar 13, 2014 | Directv Used Original RC65X Remote Control
Rf20 code for directv HR34/700 receiver
Check these codes:
503, 505, 515, 548, 579, 580, 581, 582,
583, 584, 586, 587, 625, 633, 634, 691,
698, 701, 708, 714, 715, 716
Jul 22, 2012 | Universal Remote Control RF20 LCD Remote...
Caller Id doesn't work and and when you try to access caller list won't work.
The problem is in the main base, it sends a signal to the cordless phones and that includes display data that is not being received. The only economical way is replace the whole system to get everything back. However! you can try removing the power and the phone cord from the wall outlet for 30 minutes to see if this might reset processor ic and get you up and running. "a long shot"
Jan 13, 2011 | Panasonic KX-TG1033S Cordless Phone
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
Caller ID has aparently stopped working
Based on a user's review of this phone system on Amazon, I unplugged the base station, waited a few seconds and then plugged it back in. Caller ID display and announcement both work fine.
Mar 23, 2009 | Panasonic KX-TG5777 Cordless Phone
Lost power for one second and now cannot get my caller ID to work
unplug the telephone cable from the back of the receiver and plug it a basic telephone to check if there is a dial tone. if there is a dial tone restart the receiver without the the telephone line plugged in. after it loads and u have a picture, plug in the telephone line. call the home to check. if its not working the modem in the receiver has gone bad.
Oct 20, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Got caller id from local phone co., where we also have dsl service. we can not view call id on our tv, who we have service with direct tv. how can we view our call on our tv?
make sure there is a DSL filter plugged to phone jack that is connected to the directv receiver. if u dont have one, you can pick one up from any electronics store
Jul 03, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Lands Phones Logo
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
