Question about Acer 22" X223w LCD Monitor
Acer Z223w Display Problem
I have an Acer X223w monitor. On the left side of the screen approximately 1 in over is a red line (some times yellow) about 1 or Pixels wide. It runs vertically the whole length of the screen. from top to bottom. Does anyone know what could cause this? Is it an easy fix? I can use a soldering iron, and an ohm meter, but I would need pretty detailed instructions about what to look for and so on. Any help at all would be greatly appreciated. Shane
  • Shane Black Lord Jan 20, 2013
    Thank you for you answer, but I know it is the monitor, I am looking for advise on how to fix it.
  • Tom Miller
    Tom Miller Jan 05, 2014
    Picth it out, not worth troubleshooting it,. Monitors are cheap.
    Genius:
  • Acer Master
  • 1,479 Answers
This is either your monitor or, more likely, your graphics card telling you it's going to fail soon.
Try another monitor, if that sorts it you're done. If not, it's the video source (graphics card).
Posted on Jan 19, 2013
  • Tom Miller
    Pitch it out, not worth troubleshooting it.Monitors are cheap
3 Suggested Answers
  • 8 Answers
SOURCE: Acer x223w - no option to goto 1680x1050
It would seem, somehow, your graphics driver was corrupted. The only thing to do is re-install graphics drivers. These can be found with a quick Google Search: CLICK ME
The first link, to DriversCollection.com, looks promising. This one is for Windows Vista or XP, but you need to specify on the tabs near the top of the page. Make sure you download the correct driver, as this page includes other drivers. You're looking for "Graphics Driver" [Vista] or "Video Driver" [XP].
Hope this works for you.
~Chris
Posted on Jun 11, 2009
antiochpc
  • 1314 Answers
SOURCE: My monitor has a yellow line running down the middle
This is a bad LCD panel. If it is still under warranty, your best bet is to have it replaced again. The only fix is to replace the actual panel and that would cost more than a new monitor.
Posted on Sep 28, 2009
Red and green vertical lines appear on right side of monitor
Depending on the age of the monitor, it most likely will be Capacitors that are leaking. I have repaired many different brands of monitors and have seen problems very similar to yours. 99% of the repairs I do are capacitor Issues. It's well worth replacing them IF the screen is still in very good shape as far as brightness and contrast. most repair kits usually cost between 12 and 20 dollars.
Hope this helps!
I’m happy to help further over the phone at https://www.6ya.com/expert/arturo_82cd53a2264b6f81
Dec 08, 2013 | Acer 22" X223w LCD Monitor
Red line on monitor
It's is either a screen or video card issue. Only an apple tech can repair or replace parts as needed.
May 08, 2013 | Apple Computers & Internet
My Acer X223W auto-aligns my screen 2
I was having this exact same issue. I held down the 'e' button and let it re-auto config and it seemed to clear up the problem.
May 28, 2012 | Acer X223W Monitor
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
There is a Vertical Red Line and a purple line on the screen; plus sometimes it blinks yellow.
that is a cable problem check signal cable if faulty replace it if no cable problem then there must be a dry solder inside the monitor clear it
Mar 07, 2010 | Acer 22" X223w LCD Monitor
A red line in middle of screen, traded out with other monitor and thats what im using now
Usually lines, multicolored artifact etc. is indicative of a failing lcd panel or...a loose cable connector. There is no repair for this type of problem other than screen lcd panel replacement or secure the loose connection.
Jan 17, 2010 | Acer 22" X223w LCD Monitor
Green vertical line on LCD screen
Is this on a monitor or on a laptop LCD display?
Most of the time it is due to a hardware issue like a video card or the screen itself.
When does the line appear?
A. Is it there even with the monitor or laptop turned off?
B. Is it there during the OS logo / boot screen or does it appear after the OS loads?
C. If it is a monitor, with your system turned off go into the menu of the monitor by using the buttons on the front. Is the line there?
What you can do to try and fix it is.
1. Make sure you have all the latest drivers for your video card.
2. Change the resolution of the screen.
3. Change the frequency of the monitor.
If these do not fix your issue you may want to look at getting or borrowing a video card and replacing it if this system is a desktop. If this system is a laptop and the above does not fix the issue your best bet would be to put up with it or buy a new laptop to be honest.
Jun 19, 2009 | Acer 22" X223w LCD Monitor
Acer x223W Monitor issue - not displaying correctly in native resolution
hi, when all connected press and hold the FN key on the bottom left of the keypad while pressing one of the function keys F1 to F12(the one with picture of a screen or monitor). You may need to press it more than once but if will eventually switch the display over to the tv
Hope this help
May 30, 2008 | Acer AL2216WBD LCD Monitor
1inch black line down right hand of screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 15, 2008 | Computers & Internet
Acer 22" X223w LCD Monitor Logo
146 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
