Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Xerox WorkCentre XD125F 'P' appears when I try to print...
I just picked up this printer. The printer has paper in the (only)
paper tray, but whenever I try to print (just got this, so this is the first time I'm using it) the "P" flashes.
Paper appears to be in good shape; not about the 'top of paper' line; it is under the two tabs on the right side.
When I load a piece of paper on the right 'auxilliary' feed, it works fine.
  • alvarezgirls Feb 16, 2009
    I have the same problem, only I'm using it strictly as a copier and don't have it plugged into my pc. I keep getting a flashing P and there is no paper jam. I'm wondering if it's a problem with the rollers. Do you know how to access the operating panel or reset the defaults, when it's not linked to a pc? Thanks for the help
    Genius:
  • 2,120 Answers
This printer is very dumb, you have to tell it from which tray to feed. change on the operating panel or in printer properties.
Posted on Jan 25, 2009
Need Win 7 Driver For Xerox Workcentre XD 125F
you can't find one. What you can try is install an older driver or a standard printer driver. that might give you some functions
Dec 08, 2013 | Xerox WorkCentre XD125F All-In-One Laser...
Error C0...Xerox WorkCentre 5020DN Printer
C-0 declares that the size of the document you are trying to print is incorrect with the paper size you have in your machine's tray. To remove the error, press the red button on the control panel and check the size of the document within the printing properties. If the papre size of the document and the paper in the tray are correct then try to use another tray or bypass tray. If the problem still persists, call for service.
Dec 06, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
Have a jam error. paper folds in front of print roll
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
Mar 31, 2011 | Xerox WorkCentre XD125F All-In-One Laser...
My xerox 3119 frequently pick up more than 1 paper during printing. It cause paper jam and make it very hard to print of both side of the paper. Can you help me solve this problem?
The xerox laser printer rollers have shrunk, causing the paper to be picked up in multiple.
Try to fan the paper before adding it to the paper tray.
Aug 11, 2010 | Xerox WorkCentre 3119 Laser Printer
Workcentre XD125F
Waste ink reservoir is probably full. Needs to be emptied.
Hope this helps. Bud
Jan 26, 2009 | Xerox WorkCentre XD125F All-In-One Laser...
Paper Feeder Jams
Use this link and when you call ask for Britt. I do NOT work there but I have used them for a long time and they are greart.
Here is the URL ..
https://www.partsdrop.com/store/
Jul 09, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Printing to Xerox XD125F
That will print via Parallel port , Just have to go to www.xerox.com
go to drivers and downloads and then type in xd125, dowoload the driver and use the autosetup.
It is easy to set up.
Apr 12, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Printing does not work on Xerox Workcenter XD125F
Does the printer show up when you unplug it from the USB port and plug it back in? Does it say New Hardware or Printer found?
Does it print from a parallel port or does your computer have one?
Unlikely the cable since I have used those on that product before.
If it will print from a computer parallel to parallel, I would suspect the cable obviously.
You can take the back off the printer and reseat the board, and connectors.
What happens when you popo the printer itself?
Jan 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox Workcentre XD125f problem
Does it keep showing that after you replaced the toner cartridge?
Aug 17, 2007 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
96 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
