Question about Bosch Mx25ec-21 2.5-Amp Multi-X Oscillating Tool Kit
Bosch MX25E Mullti-tool doesn't oscillate
Tool holder spins; doesn't oscillate. Motor works fine, but head doesn't oscillate.
  • Trimtone Aug 18, 2013
    The gear box pin is sheered in half. It is a $45.00 part.
  • 142 Answers
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
Posted on Jul 06, 2009
brewerstool
  • 141 Answers
SOURCE: I have a Bosch brute jackhammer, I need the tool
You can use an adjustable face spanner wrench to remove that cap. I don't remember the pin size but you can measure the holes and get the appropriate size. You can remove the whole plate with the armature by undoing the 4 cap screws. Prior to removing the motor plate you have to remove the handle plate from the axle that goes through the body. Undo the nut that holds the assembly on and slide it off. You can now remove the Armature plate. After removing the cap screws pull the assembly out about 1-2 inches. You will see the wires that go to the field attached to the brush holders. Remove the screw that holds these wires to the brush holders. You can then safely remove the whole assembly. This also makes it easier to remove that cap plug with the spanner wrench, because you can now put the whole assembly in a vise. I always heat around the cap with a torch before doing anything. Then I tap on the plug with a hammer a couple of times and voila it turns alot easier. Corrosion almost always builds up on this cap because of the different metals. (Steel and Aluminum respectfully)
Your hammer may have a broken connecting rod. To inspect this make sure you ping the cylider and body with marks so you line them up the same way. Then remove the 4 cap bolts that hold the cylinder to the body. Remove the cylinder and inspect the hammer cylinder and rod. If the connecting rod is not broken you will have to inspect the gears and pinions to make sure they are ok.
Posted on Sep 13, 2009
  • 50 Answers
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
Posted on Jul 29, 2010
  • 4 Answers
SOURCE: I have a bosch 11240 and the tool holder will not
"CHUCK" is full of dust, clean with a good cleaner lubricant, white grease before using again
Posted on Nov 07, 2010
  • 10 Answers
SOURCE: I have a bosch hammer dirill that won't chip nor drill but motor run fine
Hi, have you tried the various positions on the front part of the gearbox behind the 'chuck'?
If so, then Im afraid it must go in for repair. These are not an easy fix and personally I would recommend you ask for a 'quotation' as it could be just something simple to do with the 'Gearbox' selector, but it could also be something a lot more serious within the Gearbox.
Good Luck & Best Wishes, John..
Posted on Jul 03, 2012
How to remove gearbox from armature on MX25E
Just disassembled one today, and it wasn't easy. There's a large washer with four tabs between the two assemblies. Insert a screwdriver into the space between it and the gear box, so you're prying metal to metal, and pry for all you're worth, moving from one tab to another. It'll eventually pop loose, and leave a few marks.... One of the two ears on the rocker is broken, so it'll mean a new gearbox for me.
Apr 03, 2014 | Bosch Mx25ec-21 2.5-Amp Multi-X...
FEIN FMM250 NOT WORKING
Check Cable Or Brushes. while tool is not plugged in to wall socket unscrew three 15T torque screws check cable with multimeter for open wires look at brushes pull out of holders.
Sep 11, 2013 | Fein FMM250Q Select Multimaster...
Flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
Nov 06, 2012 | Dremel Variable - Speed Multipro Rotary...
Where can I find a 240v Bosch 11240 SDS Max Rotary Hammer drill that I can take and use in Ghana
You'll be hard pressed to find one that doesn't run on 110v. You might be able to look on ebay and buy something from the UK like this for example:
http://www.ebay.com/itm/Bosch-GBH4-32DFR-NEW-Multidrill-4Kg-Rotary-Hammer-With-Accessories-240V-/160648807099?pt=UK_Home_Garden_PowerTools_SM&hash=item25676a42bb
Or you could just get a power adapter. Make sure they will work for the amount of amps that the tool will be pulling.
Mar 20, 2012 | Bosch 1 916 SDS Max Rotary Hammer Drill...
Uses up battery quickly
If the battery works fine on another tool then the problem is in the tool it doesn't work in. Possible problems:
1. battery contacts on the bottom of the switch may be bent or broken (very common) so the tool isn't getting full voltage from the battery. Check that the four tabs are there and not bent.
2. switch may have bad connections internally, again not getting full power to tool. Switch has to be checked with an ohm meter.
3. shorted wires from switch to motor, worn brushes, or burnt windings on the armature or field. Visual and ohm meter checks need to be done to verify these problems.
Dec 27, 2011 | Dewalt Drills
My Lasko E20739 blower fan works but does not oscillate. The small 120V motor that does the oscillating seems to be the problem.Please confirm and advise where can I buy s replacement motor Peter
i don't think it's going to be a motor issue, these fans have a round plastic gear in them that commonly go bad. remove the bottom cover by removing (5) phillips head screws, then unwind the power cord from the cord holder rembering the path, then remove the (3) large phillips screws, then just slide the base of the fan off and the gear is right there. if the gear is bad, you'll know cause there'll be pieces of plastic everywhere and the teeth on the gear will be rounded off. have fun. oh, for the part, i suggest contacting lasko at www.laskoproducts.com
Aug 21, 2010 | Lasko Heating & Cooling
My Bosch 4000 table saw blade spins very slow. What the problem would be?
could be bearings locking up/seizing or do you smell any burning when running indicating the armature/field are burnt from possibly overloading with a dull blade.
Dec 17, 2009 | Bosch Saws
Locking device will not reset and lock blade in holder on a Bosch RS 15 Saw. .The locking device is up against the pin and will not rotate.
try using compressed air to blow out the area and then some WD-40 to loosen it up. They sell the holder as an assembly, You can go to Boschtools.com and download a breakdown for this tool. It is usually some debris or rust that makes them stick.
Oct 06, 2009 | Bosch RS15 1 1/4 Reciprocating Saw
Jul 05, 2009 | Bosch Hammering
Bosch 4000 tablesaw suddenly ran backwards and died
I had a customer bring me a saw with this same problem. All components tested OK on my growler. I went on a limb since the speed control and the armature tested OK. I replaced the feild since to me it seemed to be the only component that could cause the motor to run in reverse. Tool now works properly and have had no more problems with the tool.
Dec 02, 2008 | Bosch Electric Table Saws
Bosch Mx25ec-21 2.5-Amp Multi-X Oscillating Tool Kit Logo
405 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
