Question about HP EliteBook 2530p Notebook
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
    New Friend:
  • 11 Answers
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Posted on Jan 25, 2013
Murphybanton
  • 2004 Answers
SOURCE: HP Pavilion dv8000 - touch scroll pad won't work
at the top black rim around the touch pad, there is an orange light showing, press and have it show blue. It will work now.
Cheers.
Please rate this fixya.
Posted on Apr 10, 2009
  • 54 Answers
SOURCE: touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Posted on Mar 14, 2009
Nandakishore
  • 304 Answers
SOURCE: touch pad scroling up down problem
Try these links and update drivers Quick Launch Touch PAD
Hope this will help you
Thanks & Regards Nandu :)
garethmt
  • 116 Answers
SOURCE: HP Elitebook 2530p power lights stays on after
are you switching off, or just closing the lid? On most laptops, closing the lid just hibernates and constantly uses power, it can be changed in the control panel power options.
Posted on Mar 26, 2010
  • 47 Answers
SOURCE: HP Mini Touch Pad Right Mouse button auto click...
it may be a setting on the touchpad that you can set in control panel
Posted on Apr 30, 2010
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
I have EliteBook 8230W with Synaptics touchpad and Win7. The virtual scroll is erratic. It doesn't seem to send the information to the right application. I force focus but the scrolling doesn't work...
well remove all usb devices
fail now>
then go to HP.com get your synaptics driver,
this fixes it. NO OS stated by you. so no links possible
if not that the pad is bad.
Jul 19, 2017 | HP EliteBook 8730w PC Notebook
My scroll bar at the right ofmy mouse pad stoped working what do i do
  • Click the Windows Start button, select "Settings," and then click "Control Panel."
  • Step 2 Double-click the icon labeled "Mouse."
  • Step 3 Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptopmag-glass_10x10.gif; skip the remaining steps and refer to the "Warnings" section below.
  • Step 4 Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed.
  • Step 5 Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptopmag-glass_10x10.gif is now enabled.
  • Jul 19, 2010 | HP Pavilion dv9000z Notebook
    I have a Compaq Presario CQ60 scroll touchpad stop working
    The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
    1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
    2. Under Mouse properties Window click the Device Settings tab
    3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
    4. Follow the steps below to enable the Tapping Feature :
    Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
    5. Follow the steps below to enable Scroll feature:
    Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
    6. Click OK .
    Alternatively you can anble scrolling by reinstalling touchpad driver.
    Touchpad driver for Vista:
    ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
    Touchpad driver for Windows 7:
    ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
    Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
    Scroll on touchpad not working
    There are two reasons for this, wrong or missing touchpad driver, or scrolling is disabled. First go to HP... http://welcome.hp.com/country/us/en/support.html
    put in your exact model number and click on the drivers link, download the touchpad driver and install, scrolling is automatically enabled. When you download a new driver it will over-write the present one and all it's settings.
    Sep 20, 2009 | Compaq Presario Notebook
    Touch pad scrolling problem
    Mar 14, 2009 | HP Pavilion dv4000 Notebook
    Touch pad
    If you have the drivers for the touchpad installed then you should be able to run your finger up or down the right hand side of the touch pad and have it scroll the page you are one.
    If it doesn't work then you may need to either reinstall the drivers or find the program that handles the touch pad settings (usually found in program files) and turn the scrolling feature back on.
    Hope that helps :)
    Mar 13, 2009 | HP Compaq Presario 2200 Notebook
    Scrolling button on touchpad not working?
    SCROLL PAD SOLUTION THAT WORKED FOR ME!!!
    Well what I did was I went to CONTROL PANEL, went to the HARDWARE AND DEVICES, went to the DEVICE MANAGER which has a list of Devices. I found the MOUSE DEVICE on the list, right clicked it went to PROPERTIES go to the DRIVER TAB, and then click on ROLL BACK DRIVER. Restart your computer. and then repeat everything again. CONTROL PANEL>DEVICES>MOUSE>PROPERTIES>DRIVER TAB when u get back to the driver tab of your mouse device. click on UPDATE DRIVER. It will then find the driver automatically reinstall it for you and then restart your computer. HOPE this fixes your scroll pad. It did for me.
    Apr 07, 2008 | Computers & Internet
    HP EliteBook 2530p Notebook Logo
    976 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
