Question about ASUS Computers & Internet
White screen I have a completely white screen. Has been here for 5 days. Every time I open computer, it pops up. I can't even log in.
  • 564 Answers
Have you tried starting in safe mode ( press F8 on start up)
Posted on Jan 19, 2013
xerick
  • 139 Answers
SOURCE: white screen zd7000
i think this site would do u some good to carry on.
http://www.laptoprepair101.com/
thank u plz check back
Posted on May 27, 2008
  • 3 Answers
SOURCE: Screen completely white
dont warry,u just replace your lcd.
Posted on Jun 03, 2008
  • 10 Answers
SOURCE: white blank on acer 4315
It sounds like a Bios issue.
Go to http://support.acer-euro.com/drivers/notebook/as_4315.html
Download the latest Bios for the windows you are currently running and follow the Readme.txt and update the bios.
Hopefully this will fix the issue that is connect with the monitor and power setting in the bios.
Please Rate, Thanks.
Posted on Jan 06, 2009
Nate Dawg
  • 14 Answers
SOURCE: white screen suddenly appears Blank Page Windows
Try these steps first. I assume you are using IE 7. If these steps do not work try reinstalling your IE. Let me know if you need anything else. Good Luck.
Method 1: Clear cached data in Internet Explorer 7 loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
  1. Open Internet Explorer 7.
  2. Click Tools, and then click Delete Browsing History.
  3. In Delete Browsing History, click Delete All.
  4. Click to select the Also delete files and settings stored by add-ons check box, and then click OK.
A progress bar is displayed to indicate that the browsing history is being cleared. After this process is complete, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 2.
Method 2: Reset security settings for Internet Explorer 7 loadTOCNode(2, 'moreinformation'); If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
  2. Click Tools, and then click Internet Options.
  3. Click the Security tab.
  4. Click Reset all zones to default level, and then click OK.
After you do this, test Internet Explorer to verify that it works correctly. If issues still occur, try Method 3.
Note If this method does not resolve the issue, you can restore Internet Explorer 7 to its previous security level.
Method 3: Run Internet Explorer 7 in "No Add-Ons" mode loadTOCNode(2, 'moreinformation'); Internet Explorer 7 add-ons, such as ActiveX controls and browser toolbars, are used by some Web sites to provide an enhanced browsing experience. An error may occur if an add-on is damaged or if an add-on conflicts with Internet Explorer 7. To determine whether the error is caused by an add-on, run Internet Explorer 7 in "No Add-Ons" mode. To do this, follow these steps:
  1. Click Start, and then type Internet Explorer in the Start Search box.
  2. Click Internet Explorer (No Add-Ons). Internet Explorer 7 opens without add-ons, toolbars, or plug-ins.
  3. Test Internet Explorer to verify that it works correctly. If issues still occur, try Method 4.
If no errors occur, the problem is caused by one of the add-ons that typically load together with Internet Explorer 7. In this case, use one of the following options.
Option 1: Reset Internet Explorer 7 loadTOCNode(3, 'moreinformation'); Reset Internet Explorer 7 to its default configuration. This step will also disable any add-ons, plug-ins, or toolbars that are installed. Although this solution is quick, it also means that, if you want to use any of those add-ons in the future, they must be reinstalled. To reset Internet Explorer 7 settings, use Method 4.
Option 2: Use the Manage Add-ons tool to determine which add-on is causing the issue loadTOCNode(3, 'moreinformation'); Use the Manage Add-ons tool in Internet Explorer 7 to individually disable each add-on to determine which add-on is causing errors. To do this, follow these steps:
  2. Click Tools, point to Manage Add-ons, and then click Enable or Disable Add-ons.
  3. In the Show box, select Add-ons that have been used by Internet Explorer to display all add-ons that are installed on the computer.
  4. For each item in this list, select the add-on, and then click Disable under Settings.
  5. When you have disabled all the items in this list, click OK.
  6. Exit and then restart Internet Explorer 7.
  7. If issues do not occur, repeat steps 1 through 3.
  8. Click Enable for a single add-on.
  9. Repeat steps 6 through 8 until you determine which add-on causes errors to occur.
Posted on Mar 14, 2009
kd6rhd56
  • 400 Answers
SOURCE: Solid white screen on my laptop
sounds like the on-board video card is dying/ or the screen is dying too
Posted on Jul 10, 2009
White screen
Do you always shut down and unplug the laptop when not in use? Has it been cleaned recently? Fan, Vents, heatsink? Has there been ANY damage? It sounds like your Graphics Adapter. screen, Inverter, is going? Have to say exactly. Does the Laptop Overheat?
May 12, 2013 | Dell Inspiron 1545 Notebook
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Forgot my google account password
get to recovery/download mode by pressing volume up button , home button & power button, press these 3 buttons together &hold for 5-10 seconds same time then you will be able to see recovery mode there choose the option wipe data/factory reset,remember it will erase your data even though it will solve your problem.
Please rate my answer.
Apr 13, 2013 | Samsung Galaxy Y Gt-s5360 - White unlocked...
Facebook not loogging out
Try logging out in on another pc and it will log u out on that one
Nov 24, 2012 | Computers & Internet
I switch on my pc (window xp) this evening, and my pc auto restart with blue screen pop out. its say some error with name 'fatal system error'. already clean disk, de-fragment in the safe mo
turn on computer,press F* repetedly until screen shows up wth options
safe mode
safe mode with networking etc...
in dat screen select option "most recent good configuration"
and enter..next window select windows xp and enter..thats it.
after u log in.clean whole system with good virus scanner for viruses,malware,trojans all
May 19, 2012 | Computers & Internet
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
I woul like to run yahoo mesenger at start up wiht out having to ok it evry time i restat my pc. in vista i had no problem but, wiht win 7 i canot figure it out
When you install Yahoo! Messenger on your computer, the program is adds itself to your computer's startup list. Each time you boot your computer, Yahoo! Messenger, and all other programs included in the list, starts automatically. Having too many programs on the list might reduce your computer's performance. To prevent Yahoo! Messenger from loading and popping up on your screen each time you boot your computer, you must remove it from the startup list. Yahoo! Messenger allows you to disable automatic startup through the program's preferences menu.
1.Open Yahoo! Messenger and log in your account.
2.Click the "Messenger" button at the top of the Yahoo! Messenger.
3.Click "Preferences" and the "Yahoo! Messenger Preferences" dialog box appears on your screen.
4.Click "General" and remove the checkmark from the box labeled "Automatically Start Yahoo! Messenger."
5.Click "Apply" and click "OK" to close the dialog box.
I hope you find it very helpful. Thanks.
Sep 06, 2011 | Yahoo Messenger
How do I download apps on my phone? It's a new
look for the Android Market icon in your computer & open it. You will initially be prompted to log-in or sync your gmail account, all you need to do is to follow the instruction that pop up on your screen. Once completed you will find a search box where you can type in the specific application you are looking for and again all you need to do is follow the instruction your prompted to do to complete the download. Your phone itself will walk you thru..
Aug 27, 2011 | accuweather.com Android Apps
When I log on I am prompted to complete a security check---change my password, change my home email password, etc.---my "home" computer is listed as Tucker within this security check and I do not...
I guess FB = facebook. facebook have changed their security procedures trying to make it more difficult for unauthorised access. I have customers who had similar problems when trying to reset their passwords. It's no good getting mad at security features as they don't hear your frustration. the only way you're going to get into facebook is to go through the security process or open a new account.
Apr 14, 2011 | Computers & Internet
Screen never switches on
please your monitor's switch is currently ok and warking?
second time your open the cpu couver and so the all add a smps sowaked in the motherboard add is ok. and you so the smos power
is down power you changed smos power and restart the pc and chack the ok.
Sep 27, 2009 | Gigabyte Computers & Internet
Computers & Internet Logo
21 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
