Question about AT&T Lands Phones
My AT&T 1306 answering machine turns on but does not rewind
The message light keeps blinking; none of the other buttons - rewind, fast forward, memo, etc. - respond.
  • 129 Answers
SOURCE: Video will not rewind to beginning of tape.
the clutch gear needs to be replaced . you can order the part partstore.com go by brand and model easy to replace around 30.00 dls .
Posted on Jun 20, 2007
SOURCE: GE 28112 phone voicemail indicator wont turn off
I also had this problem. I have my phone thru Charter. It seems that you may need to call your telephone support (Comcast or whoever) and set up your service for voicemail. You may need to make up a pin number for this. I called Charter telephone service and the guy walked me thru the steps I needed to get set up..
This solved the problem for me.
Posted on Oct 21, 2007
  • 579 Answers
SOURCE: VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Posted on Jan 22, 2008
  • 319 Answers
SOURCE: Nakamichi BX-125 Cassette DEck
Unit probably needs belts. Over time, belts may become slack or decompose into tar-like compound. In this case, the deck will need to be cleaned and belts replaced. Take to pro/tech
Posted on Apr 23, 2008
SOURCE: answer phone,seems to have jamed,red
unplug phone from mains,remove batteries from handset and leave for half an hour.when reconnected phone should go back to default settings.
Posted on May 06, 2008
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
All messages have been deleted but message button keeps binking?????//
Most of the time your home phone service has a digital voice mail like your cell phone does. If the answering machine is set for an amount of rings that is too long the digital voice mail service will answer before your machine. The new cordless phone indicators do show messages on your digital voice mail as well as the answering machine. Depending on your home service, most of the time when you press talk and you hear a different non standard dial tone(mine pulses 3 times before going to solid dial tone) you have a digital message. You need to delete this message before the indicator light will stop flashing. Then set up you digital voice mail for a longer pickup time! This should get rid of this problem.
Mar 07, 2011 | Uniden DECT 6.0 Cordless Telephone...
How do I check voicemail for a Uniden DECT 6.0
Since you declined to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 03, 2011 | Uniden DECT 6.0 Cordless Phone ID
I need the universal codes for my verizon fios remote, otherwise another recommendation of a universal remote that will operate my tv.
Setting up the Philips RC 144 remote if the remote codes are invalid or unknown If you do not know the remote codes for a device, or if you've tried all the listed remote codes for your device and none of them work, you can search for the correct remote code by following the steps below.
Note: These steps only apply to the Philips RC 144 Remote Control. If this is not the make and model of your remote, go to the supported remote control models page and find the instructions for your specific remote control.
Searching for a Device Code
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons.
    The mode buttons blink twice.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of the Play button.
  5. Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
  6. When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
  7. Note:
    There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
    If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button.
Feb 28, 2011 | Apex Digital LD4088 LCD TV
Palmcorder PV-DV402 doesn't work with tape inserted
Have you tried with different tapes ? Could be that this one is binding inside, and the camcorder cannot move it. Will it fast forward and rewind ?
Jul 22, 2017 | Panasonic PV-DV402 Mini DV Digital...
Emerson EM-1200
to change # of rings press and hold volume up button when it says number press fast forward or rewind until desired number of rings.
Apr 22, 2009 | Emerson Em1200 Answering Machine
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
Apr 18, 2009 | Televison & Video
Fios code for Winbook TV
If you do not know the device codes for a device, or if you've tried all the listed device codes for your device and none of them work, you can search for the correct device code by following the steps below.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of thePlay button.
  7. Note:
Feb 11, 2009 | Zenith ZN-501S Remote Control
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Lands Phones Logo
96 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
