Question about Victor 1205 Calculator
Loading paper into a 1205-3 Victor calculator?
What is the easiest way?
  • nross35 Jan 25, 2009
    I am not the first user and do not have any instructions?
I just got the same calculator without a manual. Fold over one corner of the tape so it almost goes to the other edge of the paper, making a 45 degree angle. Insert the tip of the tape into the slot at the back of the calculator and push it ahead until the corner goes under the black plastic part. I had to push it ahead a little more until it was starting to come upward on the other side. Push the arrow button at the top left corner of the keypad to advance the tape.
Posted on May 29, 2009
Cut end of paper making a point and bend it down a little - will feed right in
Posted on Dec 01, 2009
What's the easiest way to change a water pump on a 2004 Chrysler Sebring
Have a mechanic do it is the easiest way. But if you are asking what is the easiest way for YOU to d-it-yourself, you would need to tell us which of the six different engines is in the vehicle, since they will all be slightly different. Be advised that there are three 2.4L engine options, a 3.0L option, and two 2.7L options. Include the VIN engine code along with the size for the 2.4L (VIN G,J, or X) and 2.7L (VIN R or T)options.
Feb 15, 2016 | Chrysler Cars & Trucks
Clear paper jam
1. Turn ON calculator and set the slide switch P/NP/IP switch to P position.
2. Remove the paper roll from printer.
3. Use a business card and insert into the printer slot
4. press the feed key to feed the business card to clear the paper jam
Jan 19, 2015 | Victor 1260-3 Calculator
How do I load the tape in the Victor 1297?
f319ovy15l9xaaaaaelftksuqmccPPress the ARROW button on the top left side of the printer. Watch the direction of the feed roll and then push the paper into it,
Apr 11, 2012 | Victor 1297 Calculator
How to load the tape in the Victor 1297
Push the ARROW at the top left side and watch for the feed roller movement. Push the paper into it and it will feed it through.f319ovy15l9xaaaaaelftksuqmcc
Paper won't feed in Victor 1460-3. Calculator works fine otherwise.
There appears to be something in the way as the paper bunches up when I start to feed it through.
Is there some way of taking the back off this calculator?
Aug 17, 2011 | Victor 1460-3 Calculator
There are gear shifts on both handle bars (diamondback cobra 24). How do I instruct my 10 year old how to shift the gears? which is easiest setting and hardest setting?
I strongly suggest taking the bike and your son into a bike shop. They will be happy to show him not only how to shift the gears, but why and when. Also they may even throw in some maintenance tips.
The easiest settings will be labeled 1 and the hardest the larger number. if you were too look at the bike where the chain is, the gears that are closest to the frame are the easiest and the ones far away are the hardest. In the back this means the largest gears are the easiest in the front they are opposite, smallest gears are the easiest.
There are a number of good books and many free instructional videos on youtube that show shifting principles. The biggest issue for 10 year olds is whether they can reach the levers comfortably.
Apr 23, 2011 | Diamondback Cobra 24 Mountain Bike Boys' ...
Please help me to load paper into the victor 1208-2 calculator
Feed the paper through the slot located just under where the roll is sitting. Once you have fed it through as far as you can, press the arrow button (the up arrow) on your calculator until it catches the paper & feeds it through the machine.
Feb 08, 2011 | Victor 1208-2 Calculator
Broken Paper Roll Holder
You must google to find the manufacture to find if anything is still available; but I have 2 ideas : 1. form a hard wire loop (from coat hanger or #12 guage steel wire) and attach this wire loopto the back of calculator case with screws (you'll need to make an eye loop at one end for the screw to go through). 2. make a small wood block that sits on the desk or table and make a wire loop that is held by the wood block and of course the paper roll is held by the wire loop. Goodluck, Macgivor.
Dec 07, 2009 | Victor 1430-3 Calculator
Need to get to the heater blender door. Easiest
it is in the middle of the dash underneath. pretty easy to get at.
Nov 09, 2009 | 1997 Chrysler Sebring
Victor 1205 Calculator Logo
797 people viewed this question
Top Victor Office Equipment & Supplies Experts
k24674
David Burbee
David Burbee
Andrew Taylor
Andrew Taylor
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
