Question about HEWLETT-PACKARD CP1025nw Laser Printer
CP1025 Stuck laser cartridge
The drum rotates to the correct color but the laser cartridge won't pull out.
  • t d
    t d Oct 26, 2017
    Unlock lever broken on upper cover.
    Find white "Triangle" on carousel and depress each side to release.
    Best if top covers removed to view "triangles" [just under unlock levers].
    New Friend:
  • 110 Answers
Please start to remove all the other cartridges and check for the paper pieces in the cartridge slots. And then retry remove the cartridge that was not pulling out.
If issue persists, please call HP Tech Support for further assistance.
Posted on Jun 28, 2014
Hp color laserjet 1025 cartridge memory error on imaging drum
If the ground spring located on the left inside wall of the printer is ok, and you have tried cleaning all the ground contacts on the cartridge, then it may just be a bad toner cartridge. Especially if it's a third party cartridge and/or especially if this problem happened right after or shortly after installing a new cartridge.
Jan 19, 2015 | HP RB3-1025 Hewlett-Packard Color Laserjet...
HP CP1025 print cartridge carousel not rotates.
If this printer is more than one year old, it may be less expensive to replace it. Sound like one of the drive gears or a motor has failed. Error lights/codes may indicate where the problem lies. These printers are notorious for stripping gears, especially if you are using non-HP branded toner cartridges.
Mar 27, 2014 | HEWLETT-PACKARD CP1025nw Laser Printer
Drums won't rotate
Open the front, leave it open. Open the top, pull out your drum. Put the drum back in, close the top. Close the front, let it rotate, and power off. Power back on and your drums should rotate automatically.
May 21, 2012 | Konica Minolta Magicolor 1600W Printer
1" thick white space down the center of the page
From the very brief description you provided, it sounds like you may have a label or something else 'stuck' to the drum. Shut down the printer, pull the drum/toner cartridge and physically look at the drum. If there is notthing on it you may have a bad laser engine. The only way to correct this would be to replace the cartridge.
Oct 06, 2011 | HP LaserJet 4050 Printer
I have a paper jam in my MFC -7420. I removed a sheet from the back but there is more stuck in the front. The message says to open front cover and remove drum. I have opened the front cover but...
Don't try to remove the drum by itself while it's still in the machine,
just simply remove the drum and toner cartridge together.
There is no lock you should just be able to pull the cartridge out.
Jun 09, 2011 | Brother MFC 7420 All-In-One Laser Printer
Magenta color very faded, but cartridge indicates it's fine and drum not automaticly rotated to replace it yet. But definetely faded, not clear colors
The printer may be dirty, the toner is deposited in front of the glass laser and unable to write properly: Clean the printer
May 12, 2011 | Konica Minolta Magicolor 2530 DL Laser...
Color bands top to bottom 3.5 inches apart
dirty miror or drum will create continuous strip like that, switch off printer, remove cables and follow:
1. remove paper tray
2. remove all toners, remove waste, remove transfer drum (how to do all that is in owners manual).
3. check in full paper path, especially on line where colouring occures, remove all debris, soft brush is fine, sometime bit is stuck on the wheel, then rotate them to remove all. do not be afraid to look "under bonnet" and turn printer on it's side if needed, if there is no toner, and you do not drop it, nothing should happend.
4. lift slightly protective shields on cartridges and check if no debris is stuck on the surfaces, soft brush should remove it if any. clean waste container.
5. put everything together in reverse order as you were pulling it apart.
6. switch on printer and check for print, if lines persist, this indicate that heating element is damaged and that is usually beyond home repair.
if 6 is correct, check if you still have valid warranty, and send it for warranty repair.
Jul 27, 2010 | Canon MF8180C Color Laser MFC Printer
HP 4550 Color Laser jet reports no "errors" yet does not print
HP 4550 Color Laserjet Printer - Blank or white pages :
01. Your software application is sending an extra page-eject command.
02. Check the software’s printing configuration information. There is a problem with the network configuration.
03. Some sharing devices on networks may generate a blank page as a separator.
04. Check with the network administrator.
05. The printer may be feeding two or more pages at once because the paper is difficult to separate.
06. The sealing tape has been left in the toner cartridge.
07. The toner cartridge is empty or defective.
08. The laser scanner door does not open properly.
09. Remove and reseat the toner cartridge.
10. Check the laser scanner shutter door for proper operation.
11. The toner cartridge guide is damaged,
improperly positioned, or missing.
12. There is no transfer roller voltage.
13. Perform the Half Self-Test Functional Check to check all other electrophotographic processes.
14. Replace the transfer roller if necessary.
15. The high-voltage connectors are mounted on the high-voltage power supply (HVPS) PCA and protrude into the toner cartridge cavity.
16. Check the springs for functionality. Clean if dirty; replace if defective or missing.
The HVPS PCA is defective.
17.The DC controller PCA is defecti  There is no drum ground path.
18 Check the drum ground.
19. The laser scanner cable assembly is defective
20 The page length and margins are not set correctly for the paper size. Verify that the ribbon connector at J1307 of the HVPS is
properly seated.
21. If the HVPS has been removed recently, verify that the ribbon connector from the DC controller PCA to the HVPS is properly
seated at both ends..
22. Verify that the photoconductive drum is rotating properly. Perform is the drum diagnostic test to visually observe if the drum is rotating.
23. OR using a felt-tipped marker place an index mark on the edge of the drum outside the image area. Turn on the printer (wait for
drum rotation to occur), and then look to see if the drum has
24. moved. If the drum has not moved, investigate the mechanical
and electrical drum rotation circuitry and movement mechanisms.
25. The imaging drum shutter may not be retracting. Replace the imaging drum.
26. Lst but not the least, please fry to have the Printer int the Setcie
27. Use only HP Authorized Genuine catridges only
Jul 21, 2009 | HP Color LaserJet 4550 Printer
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
How do I change black toner? Blue is accessible but how do I get it to rotate?
I have opened and closed the front door a number of times so that the cartridges rotate to different positions. It's trial and error until the right color is in the position to be changed.
Aug 12, 2008 | Minolta magicolor 2300W Laser Printer
HEWLETT-PACKARD CP1025nw Laser Printer Logo
320 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
