Question about Maytag Refrigerators
Ice maker won't eject icre
It is getting water, freezing but not ejecting. It's making sound like it is refilling????? Don't know how that is possible. All doors are closed. Counld it be the auger or could it have gotten moved and be unlevel?
    New Friend:
    Problem Solver:
  • 11 Answers
You need to replace the ice maker because the heater inside the ice maker is broken thats way its not ejecting the ice
Posted on Jan 19, 2013
smilemaker
  • 790 Answers
SOURCE: Ice Maker Issues
HELLO!!!
THIS MAY HELP U ...
http://www.applianceaid.com/icemaker.html#overflowing
Posted on Dec 29, 2007
aborcass
  • 2651 Answers
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Posted on Mar 25, 2008
tborn6
  • 700 Answers
SOURCE: Ice will not come out of the door. The auger is not turning
take the ice bin completely out and run water in it until all the ice is clear from the auger
Posted on Mar 29, 2009
bobicehouse
  • 1524 Answers
SOURCE: Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Posted on Apr 27, 2009
tbirdfan1
  • 3051 Answers
SOURCE: whirlpool ice maker (626662) runs water in and
Hello there
Here is some things for you to check ok
The motor turns the ejector blades which rotate until they contact the ice. Because the ice is frozen to the mold, it cannot be pushed out and the motor stalls. As the blades continue to press on the ice, the ice mold heater begins heating the mold. Once the ice loosens the ejector motor turns, the mold heater shuts off and the ice is pushed out.
so what i would first do is to check the mold heater to see if it is working
and if this is good than check the motor for the ejector blade and see if it is recieving power if it is have the motor itself checked to see if it is bad ok
I hope that this is very helpful for you there is still a lot more that can be checked but try these first ok
Best regards michael
Posted on Oct 30, 2009
1500 dodge ram I've change the water pump 4x with
when you refilled the cooling system did you put anti freeze back in it if not straight water is not sufficiant anti freeze is a lubricant for the water pump seals which could be the problemit is a must in these newer cars &trucks now it is not recommended it is demanded
Mar 10, 2013 | Cars & Trucks
RF201ADUX Fisher & Paykel ice maker doesn't make ice although we get water through the dispenser. It sounds like it recycles at times but no cubes. Any ideas?
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 10, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
Ice Maker making ice very slowly. Had just changed filter, but don't know if that is relevant.
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Sep 05, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker not making ice. control box making faint buzzing sound. water supply ok. all appears to be assembled correctly & in operating positions
NOTE: This
I'm
Leo Ponder
imufo2
Aug 29, 2011 | Refrigerators
The continetal electric ice maker works great until it starts to freeze the water; it starts making a very loud sound and does not freeze. i turn it off and unplug it. how can i fix this.
NOTE: This
I'm
Leo Ponder
imufo2
Aug 22, 2011 | Continental PortableCE-IM65151 Ice Maker...
My Ice maker in my 2 year old samsung rf267 Space Icemaker quit making ice. I don't know why or how to get it to make ice. The "ice off" isn't the reason, nor the lock. I did hear a slow...
NOTE: This
I'm
Leo Ponder
imufo2
Aug 19, 2011 | Samsung Refrigerators
Hi, my Proline frost free fridge freezer isn't keeping things frozen very well. It also takes longer than usual to freeze things in the first place. The door seal appears intact & seated correctly,...
NOTE: This
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
NOTE: This
Thanks
for using fixya
Leo Ponder
imufo2
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
Aug 17, 2011 | Refrigerators
We need to know how to set the temp.. Can't find the manual & the unit is just above freezing temp.
NOTE: This
I'm
Leo Ponder
imufo2
Aug 15, 2011 | Refrigerators
I have a magic chef model csd2525ar & it quit freezing the ice & the water keeps running
NOTE: This
I'm
Leo Ponder
imufo2
We have a LFX25960SW fridge. The Ice maker fills up with water but hardly ever freezes (slow to no ice production). The water is cool but it is not freezing the water.
NOTE: This
Leo Ponder
imufo2
Aug 09, 2011 | LG Refrigerators
Refrigerators Logo
184 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
