If it idles rough it runs rough,you just don't notice it
You can start anywhere you want
If you haven't changed spark plugs in 3 years do that
Replace any front or upstream O2 Sensors over 100,000 miles
Check fuel pressure,tps sensor voltages,check for loose air filter cover,vacuum leaks,loose O2 sensor,just go thru the entire engine,it obviously needs work & I will bet it hasn't seen much & you don't know what is done when you ask & pay for work. May sound harsh but many shops aren't there to resolve problems, they throw on as many parts as the people on this site do at home, from the questions is see here,dealers guess as well and don't road test,kind of sad really
you didn't leave much for details.. No Model number so I don't know if it's a car amp or a house amp... but I've found these very useful for solutions and support...
Service Manuals: http://beophile.com/?page_id=8253 Contact Company for support: http://beophile.com/?page_id=2202
Explain to them with full details and make / model & model number / serial number /
Only other idea is to probably buy a new one if these don't resolve your problem..
Hi, The biggest fuse to be replaced is a 30amp. I don't know what you have that is that big. Could be a relay you have. Usually under the steering wheel and left. Good luck.
is it notifieing you that there is a lens eror? or does it just not turn on?
This type of problem you won't be able to fix yourself, and don't try to either!
You will need to contact Kodak and tell them there is a lens eror (don't give details that you shouldn't be giving), hopefully they will be willing to fix it for you or replace with refurb.
www.compaq.com and look up the users manual should help you out. don't be afraid to push things you aren't gonna break it the more you play with the pc the better you will become. i also suggest getting a book on how to use laptops maybe that will help too
