Question about Nintendo Original Gameboy Gray System1989 Dmg-01, Light Boy, Game Light, Mario
Original Gameboy Won't Turn on
I have tried to change batteries and change games when starting up. Don't know what else to do. Red light doesn't turn on either.
C-m0n3y
  • 34 Answers
SOURCE: Game Boy flashing Red light
Internal damage. May need replacment of various parts, or a new unit.
Posted on Feb 21, 2008
SOURCE: game won't save on pokemon silver
if you'll going to save your file to your game boy!
follow the following instruction:
1.start
2.take save
3.then there will be a questionier about your game.
4.then always answer yes
5.then it will be saved
Posted on Jan 22, 2009
SOURCE: Won't Save
I have the same problem and i found how to fix it but im not sure if it will work because im to lazy to try it you need to find a screw driver to open up the back of the game cartrege (try ebay) then you need a small tweesers or a small needle nose plires to gently break the soddering between the battery and the game next you need to sodder a brand new CR2025 battery back in the game (try ebay, batterys+ and maby game spot) + side goes down good luck
Posted on May 08, 2009
pokefreak000
that mean your silver save battery has run dry you ne3ed to buy a new battery you can get thoughs at walmart and replace it. most celluar batters will do sorry but your old save data will be gone but POKEMON hear gold and soul silver are commin soon. in jappan their commin in fall!
Posted on May 31, 2009
  • 6 Answers
SOURCE: my gameboy pocket doesn't turn on
If any harmful materials entered your game system, like water, and any other liquids. Also, did you play it for like 16 hours? This overheats the contents and can actually cause them to melt. If its permanetely broken, those things are fricken old and you can easily by a cheap new one on Amazon or EBay or something.
Posted on Jul 11, 2010
Screen won't light up
Thought it may just be worth it to buy a new one, here is a video explaining how to fix the light manually.
http://www.youtube.com/watch?v=Vm5G6WV7rw8
Jun 01, 2013 | Nintendo Game Boy Advance SP GBA Red...
My Gameboy Advance SP won't charge the battery. And I know it's not the outlet or the AC Adapter because I've tried multiples of each.
Well that's all I can really tell you but yea you should really consider the fact it just might be to old...or maybe it needs new batteries
Oct 29, 2012 | Video Game Consoles & Games
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I dropped my gameboy original on the cement ground and now it won't work no more.
It's dead. You might want someone who knows how to fix or work on those take a look at it. Something might have been jarred lose as in connections or something. That or you could open it by yourself.
Sep 05, 2011 | Nintendo Gameboy Color Console
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
How do you know a Gameboy color pak is out of internal battery?
Well if the gamepack says new game only when you turn it on and it won't hold a save either.
Jan 24, 2011 | Nintendo Game Boy Color Console
My game will save, but when I turn it back on, there is only the "new game" and "options" displayed...I can't continue from where I saved.
there isn't a way to bring back a corrupted Gameboy game save. The reason the save has corrupted is because the small battery in the game had died. Replacing the battery might fix your game, but it won't bring back your save. Well you could use a memory stick for the game boy color and advance and orginal gameboy then instead.
Oct 20, 2010 | Nintendo Pokemon Gold
After i save my game for the first time and i turn off the gameboy and i turn it on a few minutes later it appears the option of new game and the option to continue my old game.
Sep 17, 2010 | Nintendo Pokemon Gold
Gameboy not charging
Sounds like the cells inside of the battery are weak and can't hold the charge. If possible, try a known good working battery and then charge it up. If the charge holds and you can run the battery off of it for a while then you know the original battery is bad.
If you try a known good battery and the charge still doesn't hold then it could be the main board inside of the GBA is bad and you would need to get another system unless the one you have happens to still be under warranty.
You can also try a know good ac adapter at that point as well to make sure your adapter isnt flaky but if you can turn on your gba with just the adapter hooked up then more then likely the adapter is good.
Jun 27, 2009 | Nintendo Game Boy Advance SP Console
Backlight on the Gameboy color
unfortunatley no there is no backlight for the gameboy color and your problem is a VERY common one.
Jul 29, 2007 | Nintendo Game Boy Color Console
Nintendo Original Gameboy Gray System1989 Dmg-01, Light Boy, Game Light, Mario Logo
292 people viewed this question
Top Nintendo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Nintendo Audio Player and Recorder Expert? Answer questions, earn points and help others
