Question about Gateway Computers & Internet
Cables need reconnected inside my gateway gp7-600
Someone disconnected my cables to the hard drives and pci adapter to install two cd burners. now all the cables are connected and i need to know where they go.
  • 565 Answers
It may be easier for you to read an ide hard drive primer, here's the first one that comes from google:
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
Posted on Jan 25, 2009
Need install cd burner in windows xp
IDE or SATA connections ??????
To enable CD burning for your computer is a relatively simple process in Windows XP.
All you need is a CD burner drive installed in your computer, the disk with the drivers and software that goes with it and an XP-loaded personal computer.
Once your driver is installed, the process is almost automatic.
Here are the steps you should follow to begin creating your own CDs.
Check your system requirements before installing the CD burner and make sure that your system can handle the speed and memory requirements of the drive.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Turn off the computer, disconnect the power cord and remove the cover from the case.
Check the IDE cables inside your computer.
You may be able to connect the optical CD drive to the same ribbon cable as the hard drive if it is set up as a secondary or slave drive or to a separate ATA/IDE channel by a second cable.
Find an empty CD drive slot, remove the plastic cover from the outside, slide the drive in through the back and screw it in place.
If you are using a SATA CD burner, you'll need to connect the red SATA cable from the CD drive to the SATA connection on the motherboard or on your SATA drive controller card.
With SATA drives, you don't have to fool with jumpers.
Attach one end of the separate ATA/IDE cable to the motherboard if you have an IDE drive and the other to the back of the CD burner.
If slaving the drive, hook the drive to the second connection on the main hard drive cable to the burner drive.
If you do that, you'll have to set the jumpers on the CD drive to the "slave" position.
The drive's installation instructions will show you where the jumper pins are and how to set them to the slave position.
If using a separate IDE cable, just leave the jumpers in the factory setting.
If this is an older drive, you may have an analog audio cable as well that connects to the motherboard.
Follow the installation instructions for hooking it up.
Close the case and reconnect the power cord and other cables.
Turn on the computer and let it boot up.
Open the "My Computer" folder and make sure there is a new icon for the drive that you just installed.
XP will generally recognize it automatically, but if it doesn't you'll have to reboot the computer and open the CMOS setup program.
Follow the instructions for your particular PC to open the CMOS window.
Check the ATA channels to make sure both are enabled in setup and that, if you are using a master/slave setup, that the CMOS selections match that setup.
Reboot the system.
If the CMOS settings are correct, the XP operating system will set your drive so that it uses either digital CD playback (no audio cable) or analog playback (with audio cable). To check, open the "My Computer" window, choose "Properties" then "Hardware" then "Device Manager".
You'll see a "DVD/CD-ROM Drives" icon.
Click the plus sign next to DVD/CD-ROM Drives folder.
Click it, then right-click the icon for the new CD burner drive.
Now choose "Properties".
If you don't have an audio cable, left click on the selection box for "Enable digital CD audio for this CD-ROM device".
Insert the CD burner software disk that came with your CD burner.
Insert the disk that came with the drive into the CD drive and install the software following the prompts.
If the drive doesn't come with CD burner software, Windows XP comes with a lite version of Roxio's Easy CD Creator that detects blank CDs.
Just insert a blank CD in the burner and XP offers you a "burn CD" option when you have autoplay set up for the CD-drive.
There are lots of freeware burning software on the internet.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files.
Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner.
http://www.freeware-downloads.com/nero_essentials.htm
nero 8.1 essentials free
This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs
http://nero-free.soft32.com/
Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online
Nov 10, 2013 | Broderbund Computers & Internet
DVD CD Burner Error
Suggestion: Try reconnecting drive. Disconnect power cord. Open PC and simply reattach IDE (ribbon) or SATA cable. Seen this problem with drive failures.
Aug 26, 2012 | Gateway Zx4931 21.5" All In One Intel Core...
Problem with DVD CD Burner
If you made sure that the CD / DVD is brand new (never tried to burn with). Then try reconnecting drive. Disconnect power cord. Open PC and reconnect IDE (ribbon) or SATA (red) cable.
Aug 26, 2012 | Gateway One Hd Zx4931 21.5" All In One...
I have a gateway wireless but I needed a USB adapter. I got anencore ENUWI-N3. I have it installed but don't know if it is fully installed or not. I still can't get on the internet. Can you tell me how.
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | Encore ENUWI-N3 IEEE 802.11b/g IEEE...
How 2 install a triple format sata internal drive in a gateway desk top
check for a open sata port on your computer. if there is one connect the hard drive with a SATA cable to the sata port on the motherboard.
connect the sata power to the hard drive or a molex to the hard drive if you do not have one. do not connect sata and molex to the hard drive together. if you don't have a molex connect you will need a molex to sata power adapter.
after connecting the hard drive to your pc. turn it on. in windows xp it will auto detect the hard drive and may prompt you to format the hard drive.
Mar 28, 2011 | Computers & Internet
How to open and change RAM memory and hard drive on Gateway Netbook model number LT2704u?
This netbook is really the Acer Aspire One D255. You have to pop off the keyboard, then remove 4 screws that hold the back panel in place, which will allow you to remove that back panel in order to get to the memory.
Here's a video - blurry but it tells the story: http://www.youtube.com/watch?v=6KYNTvF0-5M
Mar 01, 2011 | Computers & Internet
Can my CD-RW/DVD Rom Drive, model # GCC4320B be replaced with a hp 24x Multiformat DVD/CD Writer, dvd 1270i . I bought this unit today, but the connections don't match up? I truely appreciate your time and...
This model DVD/CD writer is a SATA drive and unless your motherboard has a SATA connector then you have a slight problem. You will need to purchase a SATA controller and install it into your PCI expansion slot, then connect your new DVD/CD drive to this SATA controller. You will also need a SATA adapter power cable converter which plugs into the 4 pin power connector.
Feb 08, 2011 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
CD/DVD Burners for Gateway 835GM PC
Your system has 4 SATA controllers which I mentioned on your previous question. Yes, they will work.
SATA drives are faster than the IDE interface drives.
Here is your motherboard:
The SATA connectors are those 4 approx. 1" vertical black connectors about a 3rd of the way down. The IDE connector is the horizontal one right on top of them.
As long as the SATA controller is set to Automatic in the BIOS, you should not have any problems. Also, the new drive should come with a SATA cable.
Jan 08, 2009 | Gateway 835GM (835GH) PC Desktop
I have 2 Gateway laptop computers and in one of them the CDROM Drive got fried. I would like to replace it with the one from the other laptop. How do I exchange them?
Before beginning, review electrostatic discharge (ESD) precautions. Disconnect the power adapter, the modem and network cables, and remove the battery before removing the hard drive bay cover. Remove the RAM door whichi s secured by one screw. Now loosen the two hard drive screws and pull the DVD/CD-RW drive from the laptop. Replace the cover before restoring power or reconnecting the modem and network cables.
For Gateway go to http://support.gateway.com/s/Mobile/Gateway/M275/3501734faq42.shtml
Aug 24, 2008 | Computers & Internet
Hard drive
You can check this link for the step by step way to reconnect your hard drive: http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
Hope that helps.....
Jun 21, 2008 | Gateway 505GR PC Desktop
Computers & Internet Logo
74 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
