Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Shuts off Sharps Aquos LC-42D62U keeps shutting off, then it will show blinking lights on the front of the TV. Then you can touch the power button and it will come back on for a few minuntes then repeat the shut down again. A tech. has replaced the power supply unit but it stiil shuts down. From reading the forum it may be a main circuit board. Are there other circuit boards in this model of TV that can cause this problem? Thank you for your time. Rick
  • 41 Answers
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Posted on Feb 25, 2010
Are you willing to sell the tv as it is
Posted on Mar 02, 2010
The lamp and power light keep blinking and i just replaced the lamp
you need to rest the time. cannot remember how to do this but involves holding down 2 buttons wile turning on the tv. volume menu i think. but could be menu and program.
Sep 19, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv is coming on for brief period and shutting down also constant flashing of green led light on front of tv
I have a plasma that does the same thing. I don't know but have been told it is probably the power supply.
Jan 11, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No power on
my tv wont turn on.what is the problem actually?thank you
Jul 04, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
Apr 04, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp aquos flat screen just shut off and the power light just keeps blinking
Call Sharp at 1-800-237-4277. There are firmware upgrades that this lcd needs to resolve issues. Good luck!
Nov 30, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power shut of
trobleshoot your power and check shortcircuit in the inverter board
Sep 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lc -32da5u
Probably needs a new main unit or power supply board replaced. Most times is main unit
Jun 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power lights keep blinking
The power light indicates a problem (usually) with an internal problem. Usually there is a pattern to the light. (for example 3 blinks then a pause, 3 blinks then a pause etc.)
A service tech can use the code to help determine the problem.
Jan 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
491 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
