Question about Casio Exilim EX-Z57 Digital Camera
System Error (OeO1)
For awhile now, everytime I turned on my camera the green LCD light would flash once. I would then have to press the power button several times inorder to turn the camera on. Tonight I went to turn on the camera and nothing happens except for the screen display which reads "System Error (OeO1)". Any tricks, explanations or suggestions on how to get my Casio taking pictures again?
  • 3 Answers
With a system error there is actually no way to fix this problem at home, it will need to be sent in for service. A system error is internal in the camera and usually is a software issue. The service center's number for Casio is 1-800-706-2534, then option 1.
Posted on Jul 14, 2007
SOURCE:
My canon pixma ip 3000 is malfuntioning, it flashes orange lights everytime I turned it on. can you help me what to do? thanks
Hi there!
Please try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt. If this doesn't work you can also try to reset the waste pad by turning the printer off. Then hold down Resume button and press Power button. Keep holding down Power button and let Resume button go. Then press Resume button 2 times then let BOTH buttons go. Green lights will flash and then stop blinking. When green lights are solid, press the Resume button 4 times. Press the Power button and the printer should turn off, if not, press the Power button once more.
Hope this helps.
Mar 30, 2011 | Canon Pixma iP3000 All-In-One InkJet...
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Canon printer error 5100
5100 seems to be a Carriage Home Position Error. Clean the plastic strip that runs the length of the carriage, it may be contaminated. Then load the tray with the blank papers.
Then reset the Printer: Following are the steps:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
8. Your printer should respond as normal.
This should work. If not, install the Driver and Software from the Installation CD provided with the Printer.
You can also download the Driver from the following link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13368#DownloadDetailAct
Select the Operating System installed to download the compatible Driver.
Jul 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Wont turn on!!
this is a error code from the manufacturer.
count the flashes
Apr 26, 2010 | LG 42LC2D 42 in. LCD HDTV
Hi ,my sx20 reset all button is disabled. how can i reset my camera settings?
Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 20, 2009 | Canon PowerShot SX20 IS Digital Camera
It shows an error massage "service error 5100"
1. Turn off printer
8. Your printer should respond as normal..
Oct 25, 2009 | Canon PIXMA iP1300 Printer
Error 22
1. Turn off printer
Jan 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
May 05, 2008 | Canon BubbleJet i550 InkJet Printer
Problem with printing
Sorry the manual doesn't help much either... this is what it says, "POWER lamp flashes alternate green and orange Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on. If the problem remains, contact a Canon service representative."
You could try the following reset code which works when reseting after emptying the waste ink tank:
Turn off printer
Hope it helps
Oct 03, 2006 | Canon i80 InkJet Printer
Casio Exilim EX-Z57 Digital Camera Logo
164 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
