Question about Black & Decker & Leaf Hog Blower / Vacuum
I followed the advice re the switch on leafhog buit cannot see the missing plastic piece. When I depress the switch the plastic connector inside slides along a guide and does not connect with the rocker switch. Is it possible to get a diagram anyhwere to see just how it should be?
  • John Hart
    John Hart Jan 20, 2013
    When the orange switch is pushed it moves white connector A. The cam C should activate the mains switch but all that happens is the cam C moves up the groove B with no effect on the mains switch. I cannot see how the black lever prevents this.
2 Suggested Answers
SOURCE: LeafHog bag tear
Found the bag on a replacement parts site:
http://www.ereplacementparts.com/black-and-decker-bv2500-type-high-performance-blower-vac-parts-c-4167_9502_9507.html
Posted on Sep 07, 2009
Machine doesnt turn on. Is there a reset
Check the screen to make sure the plastic piece is depressing the switch at the bottom...the machine will not activate to on if this switch is not on..and depressed by the plastic piece on the Flair SCREEN.
Apr 29, 2012 | Ecoquest Flair Air Purifier
Replace ignition key tumbler
The first thing you have to do before you start is take your old key and get a new key made with the right resistor pellet as your old key. They have to cut the new key to the dummy key so it will turn the lock cylinder. The car won't crank with the dummy key cause there is no pellet in it.
Your going to need a steering wheel puller and a lock ring depressor tool. Disable the driver's air bag from the yellow connector under the dash. Remove the airbag and unplug its connector. Disconnect by rotating counter-clock wise the horn connector. Put the airbag facing up on the back seat. Remove the steering wheel nut and use the steering wheel or harmonic balancer puller to remove the steering wheel.
Note: there is a mark on the shaft that lines up on the steering wheel's mark.
Remove the clock spring c clip. Pull the clock spring out enough to let it dangle. Do not rotate the clock spring or it will break later after you reinstall it. Remove the wave washer and depress the lock ring cam with the lock ring depressor tool. Remove the metal ring with picks and small screwdrivers. Remove the tool and lock ring. Unscrew the hazard switch button with phillips screwdriver. Then remove the turn signal
level cam screws from turn signal switch. Remove the three turn signal switch screws.
Go under the dash and unbolt the large connector halves. Just follow the wires that run through and under the column to find the connector. There is a plastic piece that the wires in the column come out of. Squeeze the plastic pieces tabs together and pull the plastic wiring protector out. Undo the small connector that has the two little white wires on it. Pull the turn signal switch out far enough to let it dangle. Using a pair of needle noise gently remove the key chime switch. Pull it out gentle like you are picking a nose hair. You'll see a bolt with an torx head. Remove the bolt and pull the orange white wire retainer from its hole. The ignition switch should slide out.
Tie a piece of string to the end of the white wire connector you unplugged. Then pull the white wires up through the column along with the string. Cut the string from the connector after you fish it out. Tie the end of the string to the new ignition switch white wire connector and gently pull on the other end of the string at the bottom of the dash to fish the wires down into the column. From there everything is reversed
Sep 08, 2010 | 1992 Buick LeSabre
How do you remove the column ignition switch
The first thing you have to do before you start is take your old key and get a new key made with the right resistor pellet as your old key.(ACE Hardware does these keys) They have to cut the new key to the dummy key so it will turn the lock cylinder. The car won't crank with the dummy key cause there is no pellet in it.
Sep 04, 2010 | 1993 Buick LeSabre
My 1999 Explorer's brake lights don't work every time you depress
If you have replaced the switch then u need to test the connecter to the switch, the wires break inside the plastic outer insulation cover, u can buy a repair connector from Ford to fix this.
Nov 22, 2009 | 1999 Ford Explorer
Can't load the toner because the access point hasn't spun round far enough to accept the toner cartridge
Open the front cover and look at the L/H side. You will see a hole with what appears to be a circular plastic piece inside it. On the cover itself should be a piece of plastic that sticks out. Notice that as you close the cover this enters the hole and depresse the "circular" bit inside. This unlocks the cartridge carousel so that it can rotate. Simply use a pen or screwdriver to depress the circular bit inside the hole and rotate the cartridges by hand until the right cartridge is aligned for removal. (BTW If the plastic part on the door is broken off the printer will make a loud screeching noise when it is switched on and an error will occur).
Hope this helps & good luck.
Jul 09, 2009 | Epson Office Equipment & Supplies
How to install back light in compaq presario r3360us
Hi there.
The backlight or inverter is located at the bottom of the screen behind the bezel (plastic screen surround) it's an elongated circuit board hidden behind frosted plastic, you can't miss it as all the connectors from the motherboard and the screen are attached to it.
If you need any more advice please feel free to post back.
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | Compaq Presario R3360US Notebook
Exterior rear door handle on Honda Accord 2001
To Remove Door Panel on 2001 Honda Accord:
A: To remove the plastic piece with the door lock button and door handle connected to it:
1- Remove the screw in the middle located behind a plastic cover button
2- Push (slide) the whole assembly Forward (toward front of car)
Besides the screw, it is held in place by 3 hooks on the backside that hook into holes in the metal door frame
3- Now unhook handle from small metal bar going through door by pushing (toward door) plastic clip (blue?) off of the bar, then the bar will come out of the clip hole, thus releasing the handle.
4- Depress little grey button /bar (purple painted on it)on elec. connector to seperate connector, thus releasing door lock switch
Now the whole assembly (metal handle, door lock switch, and plastic piece) will come off door panel
B: The door is held on by 2-screws, 7-plastic snaps/plugs, and 1-plastic plug.
The screws are located: bottom of hand hold and the other behind the handle, both covered by little covers that have to be pryed off to access the screws.(hint: the screw with the built in spacer goes behind the handle when you are trying to reinstall)
The 7-plastic snaps: 3 across bottom and 2 on each side. Not visible, they are mounted to the inside of the panel.
The 1-plastic plug is visible at the upper front of the panel and is the same color as the surrounding trim
C: Take off the big plastic triangle piece above the door panel and behind the mirror. Pull/pry off. It has 2 snaps holding it on. one near bottom and one near the front.
D: Light lens prys off from bottom. Unscrew (1/4 turn) the light assembly with bulb still intact from backside of panel
E: Remove the Hand-Hold/window switch assembly:
Jan 14, 2009 | 1997 Toyota Camry
DLC-7 missing a piece?
The workbowl has a spring-loaded assembly inside. You can see it through the plastic. When the workbowl cover is in place and locked, it depresses the button on the base. If this is not happening, then you need to determine whether the workbowl or the cover is at fault. Once you figure that out, you need to replace the faulty one. I usually get my replacement parts at GourmetDepot.com.
Dec 20, 2008 | Cuisinart DLC-5 Food Processor
Starter not work but can bump start nissan sunny "N" reg
Rock your car back and forth. The starter is stuck between teeth. I had a jeep that had the same problem. It had teeth missing on the starter motor. This seemed to do the trick
Oct 18, 2008 | 1995 Nissan 240SX
Black & Decker & Leaf Hog Blower / Vacuum  Logo
73 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
