Question about JVC AM FM CD DET FACE CAR STEREO
Wireing diagram for JVC KD G202 - JVC AM FM CD DET FACE CAR STEREO
j_del
  • 1586 Answers
SOURCE: wont keep memory
Most stereo manufacturers agreed on a color-coding scheme for their wiring to keep things consistent. In that scheme, red wires are run to power (ie, the battery) and serve as the ignition-switched power leads (so when the engine is shut off, the head unit also shuts off), black wires are grounds, and purple, gray, green, and white are used for the main four speakers. Blue is an antenna and/or amplifier turn-on wire. Orange is a dimmer wire (for cars with dimmers on the dash lights, this can be tapped in to also dim the head unit's lighting). Yellow wires are typically the memory wires. These feed power to the head unit constantly, regardless of whether the car is on or not, so that memory presets and tone settings are maintained. Your JVC unit should have a yellow wire coming off the back as part of the harness - this would be the one to supply power. You can run this directly to the battery - that way if you blow the fuse in the fuse box that you're considering using, you won't lose your stereo settings as well as whatever feature the fuse was utilized to protect.
Posted on Jul 23, 2008
SOURCE: JVC Wire Harness
i need to match up color wire to my 1998 honda accord
Posted on Oct 22, 2008
etirbynnor
  • 655 Answers
SOURCE: color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
Raditronic
  • 196 Answers
SOURCE: Car radio connections
Red wire to acc fuse
yellow= b+ fuse
blue= to amp amplifier
white= +left front speaker
white/black left front - front speaker
gray= + front right
gray/black= - front right
green= + rear left
green/black= - rear left
purple= + rear right
purple/black= - rear right
black = ground---to car metal
orange with white line to illimination
Posted on Apr 28, 2010
Jvc Manuals
The wiring diagram is on the last page of the manual at http://www.jvc.co.nz/assets/pdf-manual/KD-R526.pdf
May 15, 2013 | Car Audio & Video
Jvc Instruction Manuals
The wiring diagram is on the final page of the manual at http://www.jvc.co.nz/assets/pdf-manual/KD-R526.pdf
Manual and wiring diagram needed for JVC KD-S6060
You may download a copy of the instruction manual here. The installation guide is appended to the end.
Jul 12, 2012 | JVC KD-S6060 CD Player
WIRING DIAGRAM JVC KD-G343
It is available on jvc home page. click on support and then click on instruction manual
Feb 23, 2012 | JVC Car Audio & Video
I need a wiring diagram for a JVC KD-AR800
here is the link to download the manual, it explains how to set the clock
http://www.retrevo.com/support/JVC-KD-AR800UC-Car-Receivers-manual/id/989bh839/t/2/
Apr 04, 2010 | JVC Arsenal KD-AR800 CD Player
Need wiring diagram for plug on back of jvc kdg420
Visit books.jvc.com
http://books.jvc.com/booklist.asp?Model=kd-g420
Download the installation manual for free
Feb 28, 2010 | JVC KD-G420 CD Player
Need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
Aug 16, 2009 | Car Audio & Video
JVC AM FM CD DET FACE CAR STEREO Logo
109 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
