Question about Kitchen Ranges
Oven door doesn't close properly
The doesn't close tight against the seal.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Model number?
Posted on Jan 19, 2013
  • 126 Answers
SOURCE: Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Posted on Nov 23, 2007
aborcass
  • 2651 Answers
SOURCE: oven door won't close tight
order and replace door springs part # 32052801 youll need 2
Posted on Feb 26, 2008
  • 42 Answers
SOURCE: Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
Posted on Dec 21, 2008
SOURCE: Oven Door will not close properly
THE OVEN DOOR DOES NOT CLOSE ALL THE WAY, THE HEAT SEEPS OUT, CAN YOU HELP ?
Posted on Feb 08, 2009
jumptrout51
  • 3361 Answers
SOURCE: Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Posted on Mar 08, 2009
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
Mar 22, 2012 | Electrolux ICON Microwave Combination Oven
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Sep 01, 2011 | Neff B1421 Electric Single Oven
Runs but doesn't heat replaced two fuses and magnetron still doesn't heat
Here is your free answer in under 10 minutes ...
You have a faulty door safety interlock switch. I wish you would have searched your problem here before you spent all that money on the magnetron. I have answered this question dozens of times here at this site.
When the oven runs but doesn't heat, more often than not it is nothing more than a faulty micro switch in the door latch system. When the switch doesn't work properly, the oven doesn't know the door is closed. If the door isn't closed, the oven will not energize the magnetron. Capacitors and magnetrons are **** and expensive answers but these items are extremely tough. It is the tiny contacts in the micro switch that can not stand the repeated abuse given them when we (read me in that number too) open the oven while it is energized causing a repeated flash across the contacts.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Microwave Ovens
Can not close the door
how do you mean it won't close?it doesn't latch or are the hindges damaged and the door isn't closing tightly
Apr 16, 2011 | Whirlpool RBS305PDS Electric Single Oven
The doors on both ovens do not close tight. Are there replacement hinges? where can I get theme?
Same on ours... one seems like it is just softly lying against the gasket without a solid tight seal... doesn't bother the cooking much, it seems, but I hate little problems like this!
Will follow this thread to see if there is an adjustment for a DIY'er, without having to make a $120 service call...
Feb 12, 2011 | Bosch HBL 755 Stainless Steel Electric...
Oven door will not shut tight at top
The door is not tight per say. The seal is hat determines if it is properly closed. Check to see if the seal is tight all the way around(use a strip of paper to check consistency). If it is not sealing the hinges are tweeked and need replacing.
Eric
Feb 22, 2010 | Kitchen Ranges
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Oven door not closing
I was having the same problem with my frigidaire oven door. I was thinking that it was the seal getting in the way at first, but then I realized that the hinges needed to be repositioned. I wasn't in the mood for that kind of reengineering, so I came up with a better solution. Magnets. Not those **** fridge magnets either. Neodymium magnets. Place them on the upper part of the inside of the door, near the door lock (outside of the seal). You'll only need about three or four depending on the size. (get the fatest ones you can). If you know a computer geek you might be able to get a few free magnets from an old hard drive. I used five of these and I can just about pull the oven out of it's place while trying to open the door. The onhly problem is that heat destroys magnets and I can't say how long these will last because I just figured this out tonight.
Dec 27, 2007 | Frigidaire Ovens
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
