Question about Dryers
Sorry about video Samsung electric dryer runs for about 4 min and turns off no matter what cycle.so the sensors in the drum are out of the question.when it stops I can start it right back up.No error
  • 3 Answers
What is the model and s/n of your unit? It sounds as though the control board is going bad or you have a loose connection at the control board.
Posted on Jan 18, 2013
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
TheMobilian
  • 8220 Answers
SOURCE: Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Posted on Feb 04, 2009
SOURCE: My Samsung electric dryer, model DV337AEG is
You have a bad heating element. I just went through the same problem with mine
Posted on Jul 26, 2009
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
said291103
SOURCE: f:03 error keeps recurring
F03 MEAN SENSOR DEFAULTPUMP OR LENT
Posted on Dec 04, 2011
Dv218aew Samsung dryer shuts off itselft after 30 seconds
Bad venting causing overheat? bad thermostats hi limit and cycling? thermal cutt off. bad moister sensor in the drum? giving wrong reading and cuting it off?
Sep 04, 2014 | Samsung DV218AEW Electric Dryer
My drier was on the sensor cycle and was supposed to run for 54 mins. It was still drying over 2 hours later and the display showed there were 42 mins remaining in the cycle. The clothes were completely...
More than likely the temperature sensor has gone bad. If the unit is under warranty I would contact the dealer...otherwise you need to replace the sensor.
Sep 01, 2011 | Samsung 7.3 Cu. Ft. Super Capacity...
Samsung dryer DV328AER doesn't turn off
My Samsung dryer 8KG (SDC3K801) is not turning off after completed the cycle time. The panel showing end but the drum still running. If I choose Synthetics extra dry with auto cycle time 49, when the timer at 6, the display increased again to 25. It's seem the dryer is not stopping forever. Any suggestion please!. Thanks
Jul 20, 2009 | Samsung DV328AE Electric Dryer
Timer stops at 6 and dryer continues to run
The moisture sensor is in the lint filter. Remove 4 screws from inside the drum and you have the sensor attached by 2 wires. On my dryer I disconnected then reconnected these 2 wires, reassembled the lint trap and auto dry works fine again.
Apr 21, 2009 | LG DLE2514 Electric Dryer
Dle2532 lg dryer, cooling light is always on
I'll take a stab that you use dryer softener sheets. These will deposit a coating on the two metal sensor bars (about 4 inches long, very near the lint filter inside the drum) which prevents the sensor from "seeing" that the clothes are still wet, so the dryer jumps to the cool down portion of the cycle. Clean the metal bars off and it should work again. (note: the bars are not in the cycle if you choose time dry instead of using the automatic cycles)
Apr 11, 2009 | LG DLE2532W Electric Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Dryers Logo
46 people viewed this question
Top Dryers Experts
