Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Peavey CS-800 PA power amp 1 channel is out
Channel ''B'' works fine. Channel ''A'' is out. I have checked virtually every component in channel ''A''. I have test equipment. I have compared resistance and diode meter readings between the good and bad channels I have been an electronics tech for over 30 years. This one has me stumped. The -85V is low at about -55 volts only on the bad channel. I have a schematic, but I can't figure this one out. I have meters, a scope, and also a curve tracer. I have metered all the output transistors - they checked good...someone has replaced 2 of the output transistors previously as they are not the same as the others. Channel ''B'' ' s outputs are all the same like the majority of the parts in channel ''A''. I am hesitant to swap the outputs or the driver boards as I am afraid to damage anything in the good ''B'' channel therefore losing my ability to compare 1 to the other...I have about 10 or 12 hours into this now and I am about to return it to the owner and tell them I can't fix it. any help is greatly appreciated Thanks Bill
  • 1 more comment
  • billmorris52 Jan 26, 2009
    Hello: I am trying to fix this amp myself. I do not want to have to pay others to fix it as it will probably cost more than it is worth. Do you have any knowledgable electronics technicians that know this amp or have I wasted 10 bucks with fixya ? Thanks Bill
  • billmorris52 Jan 27, 2009
    OK: The voltages are now reading the same. +76.5
    and -76.5 volts...using your idea of an overheated component I found that Q6 on the bad channel which is the negative predriver transistor is getting very hot. The same transistor on the good channel is not. The voltages are all wrong in that area too...
    The Schematic I have is a bad copy made a while back. You can obtain a copy from Peavey usually within 2 business days via a request tohttp://www.peavey.com/support/contactinf...
    ask for the old madel CS-800 thats' what this
    is...the original model ( probably 20 years old or more) Thanks Bill. In the meantime I'll take out Q6 and test it. If bad I will replace it....
    As I said in my original post. I have tested all of the output transistors ( all 12 of them)
    on my curve tracer in the bad channel....they all check good to beyond their rated voltages...so I don't think it is the finals....Q6 predriver is hot and nothing else...will remove Q6 and see whats up there and report back in a day or 2. Thanks Bill
    Problem Solver:
  • 17 Answers
I Have a CS800 with one side that was intermittant - found the solder joints cracked around the pins on both back side circut boards where the input and output jack are soldered in- input jack connection would open up and drop audio to that side.
Posted on May 04, 2013
    President:
  • 2,976 Answers
If you have unbalanced speakers, you will usually blow out an output transistor. You need a transistor tester to verify this. Make sure you have EXACTLY the same impedance on both sides of the output.
Posted on Jan 27, 2009
  • 50 Answers
Try to reinstll
    Sergeant:
    Novelist:
  • 326 Answers
For all the details with diagrammattic designs and repairing procedure of cs-800.click the the link below and check out step by step metod of amp repairs.: http://www.amprepair.com/peavey.htm
rate the solution if it helps you fix your problem.thanks
    Sergeant:
  • 221 Answers
As the amplifier needs to be opened with a proper tools and checked with he meter to locate the faulrty ic or capacitor.as it will be bulged or leaked.
Posted on Jan 26, 2009
  • 19,396 Answers
One of the Amp channels is out because one of the power transistors on the amp final is gone.
Test the transistor and replace it.
See: Sci.Electronics FAQ: Repair: Power Amps Repair
  • Ginko
    Ginko Jan 27, 2009
    If you have tested all trans, and there is no audio on one channel, then test the controls circuit (balance). Test also output from preamp.
    More the schematics you need to get from Pewey a full service manual with troubleshooting diagrams, as this is no common problem.
    You can download free schematics here To download the file, please, click here !, but that is probably what you already have.
    Get full repair manual from Pewey.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
For the -85 to read only -55 would indicate that one of the output transistors has a leak and is loading the power supply. You can verify this be feeling which one is heating up even with no input signal. Since it would be a matched pair, then both outputs of Channel A has to be replaced. Measure the output transistor out of circuit and check collector to emitter to base reverse bias (for leak). Additionally, you may want to check the driver transistors, again for leaks.
Could you post the schematic on a free online file server? Pls post back results. Good luck and thank you for using FixYa.
Posted on Jan 25, 2009
  • Louie  Role
    Louie Role Jan 27, 2009
    Appreciate the update/postback.
    I have emailed to request for a copy of the schematic diagram. Soon as one is available, will postback for more insights.
    In the meantime, pls bear in mind that designs of this period tends to have a "domino effect" that is; if one of the transistor fails, then suspect those before and after it as well.
    Cheers.
  • 350 Answers
Dear FixYa Customer,
In reference to:
peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000...
peavey CS-800 PA power amp 1 channel problem
listed on FixYa Site.....
I read this review of a new PEAVEY Amp @
http://www.musiciansnews.com/live_sound/49/peavey_pv900_stereo_pro_power_amplifier.shtml
"The new PV Series power amps retain their two-channel design, high power points and exclusive peavey features and technologies—such as DDT compression and Turbo-V Cooling. The PV 900 delivers 300 Watts per side into 4 Ohms, 180 "
This makes me believe they've had problems with the channel on other models like the one your trying to fix!
I'd try them direct at this point in your attempt to fix this problem. It looks like they have a great PEAVEY CUSTOMER SUPPORT SITE which I always say "You Should Call 1st!" @
http://www.peavey.com/support/contactinfo/
Peavey Customer Support Site Listed below:
Customer and Technical Support If you have questions concerning product operation, support and warranty, contact one of our Customer Support Representatives toll free at 877-732-8391, by email at customerservice@peavey.com, or by using our Forums.
Parts Department To order replacement parts, please call us at 877-732-8391 (toll free in the US) or 601-483-5365. The Parts Department extension is 1386. Our business hours are 8 a.m. - 5 p.m. Central Time, Monday-Friday. Hold times may be long during peak hours. If you have to wait on hold, feel free to leave a name and number and one of our Parts Sales Coordinators will contact you as soon as possible. Payment can be made via credit card, or we can ship COD to a place of business only.
For parts pricing and availability inquiries only, email the Parts Department at parts@peavey.com
Pricing In the U.S.: domesticsales@peavey.com
Outside of the U.S.: intsales@peavey.com
Repair Assistance To locate an authorized peavey Service Center near you, click here.
For assistance/status of repairs for peavey products and scheduling factory repair appointments, email repair@peavey.com
Marketing Contact Information To communicate with Peavey's Marketing Department concerning marketing or branding opportunities,
email marketing@peavey.com
Product Development Contact Information To contact the product development department directly,
email productdev@peavey.com
For any comments or concerns regarding existing peavey products, please contact our customer service department,
Your Nearest Dealer In the U.S.: U.S. Online Dealer Locator
In Europe: EU Online Dealer Locator
Outside of the U.S. and Europe: intsales@peavey.com
Human Resources hrdept@peavey.com
peavey.com Website webmaster@peavey.com
Corporate Contact Information International Headquarters
peavey Electronics Corporation
5022 Hartley peavey Drive
Meridian, MS 39305
Customer Phone: 601-483-5365
Fax: 601-486-1278
Europe
peavey Electronics LTD
Great Folds Road, Oakley Hay Corby
Northants NN18 9ET England
Tel: +44 (0) 1536 461234
Fax: +44 (0) 1536 747222
Website: www.peavey-eu.com
Hope this is helpful.
Good Luck!
jackiaria
  • Jack Iaria
    Jack Iaria Jan 27, 2009
    Have you tried music-electronics-forum where they have repaired the same problem? They give links to downloading schematics, show photos of the unit and places to order parts!
    The link http://music-electronics-forum.com/showt... will take you directly to info on the amp your going to fix!
    I'd dive in deeper but I must go to work now!
    Knowing YOU CAN FIX THIS!
    jack
  • Jack Iaria
    Jack Iaria Jan 28, 2009
    How you doing with your Peavy Guitar amp repair?
    Please rate me!
    Thanks
    jackiaria
2 Suggested Answers
  • 32 Answers
SOURCE: Peavey PV 8.5C DDT is activated on channel A even
Check your speakers and Cables. I had some speakers that traveled in my small trailer and the vibrations of the trailer caused the diaphram to back off my horns. Once I got the speakers fixed the DDT light on my power amp stopped staying on so much.
Posted on Jan 20, 2010
Right channel not working on yamaha rx v793 receiver
If the channel is dead on headphones suspect a fault in that channel. The good news is that you have the good channel to compare it with. Since the channel parts are identical. You can start with a visual check. Looking at the good and compare with the bad. Any bad looking parts should be replaced. If you are experienced with electronics you can do tests on the channel. Otherwise it is off to a repair shop with it.
Jun 01, 2016 | Yamaha RX-V793
Some dtv channels missing on VIZIO
Have you tried doing the channel search? If that does not help replace the main board
Apr 12, 2014 | Vizio VL370M LCD TV
The channel 1 the light red is on
As always with stereo amps the two channels are identical, so if one goes wrong you have the other as a control for testing purposes. So if you start by looking and comparing the two channels. that's a start! If a part looks odd on the faulty channel, but is fine on the good channel you have found the problem. You can also do tests, such as touching the two channels with an insulated screwdriver, while powered up. If it buzzers on the good channel, it should buzz on the other channel at that point. Keep away from the power supply and ignore anything that is on it's own, that has no duplicate, or is common to both channels.
Feb 10, 2014 | QSC GX5 2Channel Amplifier
Channel 1 makes a pulseating click and NO sound through it . All other channels are fine!!!!!!!!
Operational amplifier circuit named 4580 is the issue as with most of mixing boards, each channel has its own operational ic's and one way to know which one is defective is simply touch every one on the board, inside of course, of the non-working channel, check for excessive heat and if you find one pretty hot compared to other you just find your bad component, you will recognize what type of ic im talking about, is a 8-pin smd ic where the pin 4 should have -15v and pin8 should have +15V, no other pin should have any voltage and this is another way to test an opamp, with a dmm in dc volts referenced to ground, chassis ground, let me know if you need further assistance.
Sep 18, 2013 | Behringer XENYX 2442FX Mixer
Toshiba lcd tv 32" making noise by speaker
test this steps and fix it. God bless you
Line noise is feeding in from the AC line. Use an AC liner filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Jul 25, 2013 | Toshiba 32AV502U 31.5 in. LCD HDTV
I have a 1975 Sansui Integrated Stereo Amplifier and Left Channel on System A & B are faint and Tinny as if Left Channel in System went out. I swapped speakers from right to left channel and same...
It's likely there is a fault on the power amp. This is located on the heatsink. A visual check inside the unit might be what you need. Look out for blown parts, bulging capacitors or burnt components. Remember the two channels are generally separate and identical. So identify the two channels. Work back from the speaker sockets if you can't tell. Then compare the left channel parts with the right side components. If it looks odd on the left compared to the right you have found the problem.
Feb 14, 2018 | Sansui RZ-5300AV Receiver
Hi Bill,
It's a log time ago that I repaired those amps., but I give it a shot.
There's a speakerprotection after the finals, what I remember it's a triac (SAC187, or something like that).
You will find it at a small pcb at the back of the amp. Normally it has three legs but the centre is cut away. If it's down you will measure 0 Ohm at the output, also with a switched off amp.
Thats all I can remember, it was about 25 years ago.
Maybe it helps,
Gerard
Jan 25, 2009 | QSC MX1500A 2-Channel Amplifier
No sound from "Front Right" channel
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: MOST HK equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take this beast in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the left front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. HK is among the best equipment money can buy, and their equipment is pretty much "bullet proof!" Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 02, 2007 | Harman Kardon AVR 325 Receiver
One channel not working
could possible a bad bias resister. easy enough checked with a meter for ohm. also check around the circuit one the side that gets hot see if the transisters farther in are getting hot as well of if they seem out of range on a meter. One thing I have found is if you look carefully at an amplifier stage it is pretty bisymetrical. so use measurements from one side to compare to the other. Sometimes this will give clues.
Aug 04, 2006 | Verge VGA285 Car Audio Amplifier
Open Questions:
Car Audio & Video Logo
1,471 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
