Question about Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer
Hotpoint wd440 washer dryer fault
The dryer is not heating up and keeps blowing the main house fuse
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Sounds like the heating element of the dryer may have come loose and is shorting against the metal dryer box on top of the drum.
engineer job if you're not electrical
Posted on Jan 27, 2009
Tumble dryer blows main fuse
check fuse rate on dryer if same rate. check dryer for amps if pulling to many will blow fuse, if dryer is ok check from plug in to fuse.
Jul 29, 2012 | Hotpoint Dryers
Hotpoint WD440 washer/dryer wont control.when plugged in 4 lights flash and it goes to pump out . no switch has any effect. the lights flashing are the on/off ,drying high heat.reduced creases and time...
The NTC for the dryer is situated on top of the dryer heater box, fault can often be caused by a simple broken wire, they are very weak at this point.
its the sensor on the dryer
if you take off the top, its mounted on top of the dryer box, usually has a white plug with 2 black wires attached
Dec 13, 2011 | Hotpoint Ariston WD440G Front Load...
I keep blowing my fuse
if the fuse is the right load for this dryer but keeps blowing then there is a sever fault in the dryer this could be in the wiring loom or more likely in the motor the dryer is pulling far to many amps and the fuse should then blow to protect the house wiring from catching "fire!"
yes i did say "fire!" so dont try up-rateing the fuse,,,,thats asking for it!
i would not use this dryer till you have it looked at,,,you will be risking a dryer or house fire if you do,,,
Aug 08, 2010 | Hotpoint NBXR463EBWW Electric Dryer
MY HOTPOINT CONDENSER TUMBLE DRYER NO LONGER HEATS UP. IT NOW OMLY BLOWS COLD AIR
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Nov 17, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD440 tripping out as soon as program is select
it sounds like you have a direct short in the wiring some where on your machine.the only other option is the main control board needs to be replaced
Sep 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 23, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
No heat in washer nor dryer
hi i think the  heating element or the motor belt has torn out,check it
thank u.........
Mar 08, 2009 | Washing Machines
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Aug 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 flashing dryer heat button and onoff button !
I had to have a tech come out for the same problem two weeks ago. They had to clean the lint collector which you cannot get to on your own. He said now that this has been done everytime I use the machine, take the clothes out and then run a rinse spin cycle.
Aug 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Washer dryer
HI IT ALL DEPENDS ON WHICH LIGHTS ARE FLASHING AS DIFFERENT LIGHTS ARE DIFFERENT FAULT CODES I HAVE A FAULT CODE LIST BUT UNFORTUNATLEY ITS AT WORK & IM NOT BACK IN TILL FRI SO IF YOU CAN HANG FIRE TILL THEN I MIGHT BE ABLE TO HELP YOU OUT
Jul 30, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ariston WD440G Front Load All-in-One Washer / Dryer Logo
306 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
freddyfox
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
