Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Our water line is black, but the back line from teh wall is clear
We want to change th line, but we can't figure out how to take the door apart to find the line from the bottom up the freezer door.
    President:
  • KitchenAid Master
  • 2,651 Answers
No need to undo the door to replace this line, youll need to re-order a new line( it comes as a predetermined lentgh with a spout attached at end, ther is a quick disconnect under the ffreezer door and it simply pushes through fromt the spout end followin a premade opening in the door,
Posted on Jan 26, 2009
Why does ice form on the floor under the freezer drawer? [Refridge with bottom freezer model 79578092
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Mar 01, 2015 | Refrigerators
Why is water leaking out the back and onto the floor of my Kenmore Elite Bottom Freezer Refrigerator?
Aug 16, 2014 | Kenmore Refrigerators
Manage my life com sears
Jun 30, 2014 | Kenmore Refrigerators
Water dripping from freezer
May 07, 2014 | Samsung RF4287HARS Stainless Steel French...
Water puddle forms on the floor in front of my GE TBX18SISERWN frig
lokk under the crisper draws,if there's water under them you have a blocked drain in the freezer.if there's no water under the crispers check the pastic water lines going to the water valve and the ice maker.if it's the drainyou have to pull everything out of the freezer,remove the inside back wall of the freezer and melt out all the ice with a hair dryer then you have to clear the drain,i use a steemer to do this,you can use a turkey baster or anything will push air down into the drain hole,pour hot water into the hole and when the water goes down the drain you'll know it's clear.before you start you can advance the timer into defrost to help melt out the ice or shut down the control or unplug it,you don't want it to be running while you take it apart.hope this helps you figure out where the water is leaking from.
Sep 24, 2011 | Refrigerators
My whirlpool model et8chmxkt04 refrigerator has water in the refrigerator which I assume comes from the freezer. I don't have visible ice buildip anywhere. Shirley
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 02, 2011 | Refrigerators
No water from dispenser
I had the problem with the water dispenser not working.i tried all kind things finally I figured out the water was freezing ing the door. I cut a piece of 1/2 styro foam out that covers right below where the ice is dispensed just a square and use double sided tape to stick it to the back side of the door and haven't had anymore problems.
Nov 13, 2009 | GE Refrigerators
When use water dispeser water comes out from behind the refridge
no real "schematic" available showing how hte water lines are run, but illtell you that they start at teh rear of machine,incoming water, form there they travel to the water filter and into an opening under the refrig side. can be viewed by removing hte lower crisper(theres a holding tank) from ht tank goes back out nad heads for the door assy, so a simple trace of water lins will determine point of leak, usually a fiting or hte water lineitself has dry-rotted, in which case needs replacing, hter are no "hidden" lines with refrig, ohter then within the freezer door,and even that can be removed and replaced if ness.
Dec 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser...
I had the same problem, in reading a bunch of other similiar issues with various models, the best thing I found was that the water line inside the freezer door is frozen. I had to isolate this portion of my water line from the wall all the way through the frigde. It you unplug, take out screws from he back cardboard cover so you can follow the waterline through the fridge. The valves are pretty easy to take apart/put together. To take apart a valve, just press down on the ring around the valve the pull the connecting apart. To put back together, push the same ring down, then push the connection back together. To check the water flow, plug the fridge back in and have some one push the water dispenser as you check each valve. I suspect the problem is in the freezer door, so you should just check the valve under the bottom left side of the freezer door. From here to the dispenser the water line goes through the door. I used a blow dryer to heat up the inside of the freezer door just behind and below the dispenser unit for about 5 minutes. Try and run the water again and it should work. Good luck
Oct 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
