Question about Samsung LA22A450 22 in. LCD TV
Ineed a service manual for samsung la22a450 - Samsung LA22A450 22 in. LCD TV
My tv always standby no tv on
Hi, The power supply board in your tv needs to be repaired or replaced.
Oct 11, 2014 | Samsung LA22A450 22 in. LCD TV
My tv takes time to turn on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 06, 2014 | Samsung LA22A450 22 in. LCD TV
Have reset samsong la22a450 and still no channel
SAMSUNG LCD 22IN MODEL LA22 A45OC1LXL MOTHERBORD MY PH9030932645 CALLME
Jan 13, 2014 | Samsung LA22A450 22 in. LCD TV
White screen
Shorted chorma processor IC at main board. Contact any service technician.
Jan 05, 2014 | Samsung LA22A450 22 in. LCD TV
Samsung lcdtvla22a450c1 only stand by mode no display
This is a common problem with this model Replace the main board.
Dec 22, 2013 | Samsung LA22A450 22 in. LCD TV
Model no.LA22A450C1 5.VOLTAGE absent
Going to be hard to trace since no schematics are usually available except to authorized service centers.
The 5 volts should come from the standby power supply which is usually part of the main power board.
If you feel lucky you may want to buy and swap the board out.
Also with set off check for a short to ground on that line.
Dec 23, 2012 | Samsung LA22A450 22 in. LCD TV
How to connect cable tv
you need a cable provider they will provide a controller that connect your audio video input.
Apr 04, 2010 | Samsung LA22A450 22 in. LCD TV
Samsung LA22A450 22 in. LCD TV Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
