Question about Garmin GPSMAP 172C GPS Receiver
Need transducer for 172c ?
Have a garmin 172c need trnsducer or sonar which one do i need & PRODUCT #
4 Suggested Answers
wwjdcgh
  • 114 Answers
SOURCE: no satelite acquisition for garmin 172c
you need to go outside in an open area with no trees around and turn the garmin on untill it receives a sat connection it can take several minutes for it to find it
Posted on Mar 10, 2009
joshblaine
  • 65 Answers
SOURCE: I need to connect a
The steps to do this is quite extensive and I believe are best understood straight from the manual.
Here are links to the fisfinder 160 and 120 if you do not have them.
http://www8.garmin.com/manuals/FishFinder160_OwnersManual.pdf
Posted on Sep 17, 2008
Ironfist109
  • 3018 Answers
SOURCE: I have a Garmin 182c
If you nicked it good enough yes it can. If the receiver doesn't detect the transducer, a digital message on the display will indicate this.
Posted on Mar 18, 2011
My Garmin 421s works perfect but sonar goes off with notification that the tranducer is off. A tap on the case would partly restore service. What is the cause of this failure?
Short in system. if in warranty send to manufacturer. If not open the case and see if any components and wiring are damaged or wire came lose from mother board.
Jun 11, 2016 | Garmin Gpsmap 421s Chartplotter with Dual...
Garmin fishfinder 160c sonar failure
Hi Lakshmaan:
The first thing I would check would be the electrical connections from the transducer, and the transducer wire.
Jun 07, 2016 | Garmin Color Fishfinder 160c
How to solve sonar failure(Showing on Display) in garmin 160c fishfinder.
I would guess that "sonar failure" would mean that no signal is being received from the transducer.
Trouble shoot accordingly.
Garmin 551s sonar stopped working, no bottom definition or ability to see fish GPS charts and speed all work It shows 3 step image repeats top of the screen / water surface has the transducer packed
Check you transducer cable route and connections. Look for kinks, punctures, & tears in cable. Visually check the transducer for damage. #2 check the units operation on a friends boat with the same set or research a local marine repair shop to check ops. Best of luck on the problem.
Jan 11, 2016 | Garmin Boating
I am thinking about buying a garmin 451 chartplotter, can I connect this to my garmin 160c fishfinder for sonar capability?
Hi James!
According to the owner's manual, the 451 can be used as a fishfinder when connected to a transducer. I would contact Garmin directly to see if the ducer from your 160c is compatible with a 451. If it is, you're in business! You'll likely have to cut/splice cable, but it'd be far easier than replacing the thru-hulls. (The 451 does come with transducers.)
It has been my experience that Garmin is REAL good when it comes to answering questions from consumers.
http://www.garmin.com/us/support/
Dec 26, 2014 | Garmin Boating
Garmin 498
burned up get a new one they do that at times( no bottom lock)
Sep 15, 2013 | Boating
I have a Garmin 182c with a garmin GSD20 sounder unit ,if my transducer wire is cut or nicked would it cause the unit to unit to read " sonar turned off" ?
Mar 18, 2011 | Garmin GPS
My Garmin 400c dual beam transducer keeps freezing up, it will flash "0" depth and then go to a "updating software" screen.
check your battery voltage. Low voltage can cause errors end prevent the sonar from starting up. If charging the battery doesn't work then contact garmin for a replacement.
Nov 30, 2010 | Garmin Fishfinder 400c With Dual Beam...
Display reads sonar timed out
check the battery voltage as low voltage can cause the unit to display errors and prevent the sonar from starting up. This unit is more sensitive to low voltage than many other electronics. If charging the battery or replacing it with a known good battery doesn't work then contact garmin for a replacement of your fishfinder.
Nov 18, 2010 | Garmin Fishfinder 400c With Dual Beam...
Soon after leaving the dock the sonar goes off and sometimes reads disconnected. Checked all the wires but still no luck. Seems to go off as we speed up. Any ideas? Regards Roger
My garmin suddenly was doing the same thing. After 5 days of fristration my wife disconnected everything at the unit, as did I many times with no luck, and now it is suddenly working.
We had much rain, it is possible water is in the contacts, but just a thought with that one. My guess is just vibration, and the contacts were loose. Also, make sure your transducer is clean from algae and junk, this will impeded image transmission also.
Aug 23, 2010 | Garmin GPSMAP 172C GPS Receiver
Garmin GPSMAP 172C GPS Receiver Logo
59 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
