Question about Apple MacBook Air
How to save and export Pages files
I want to save and export a Pages file so I can print it on a PC with Word
  • 147 Answers
In Pages under the "File" menu there's an "Export To" selection that has Word listed as an option along with other choices. I'm using the version 5.2 of Pages, so your's might be different.
Posted on Jun 05, 2014
How to repair illustrator file?
And also u can use the same program Illustrator Repair Toolbox
But with working link below:)
http://www.illustrator.repairtoolbox.com/
Dec 15, 2014 | Adobe Illustrator CS3 - Windows for PC...
Can i use a picture saved in a file for my wallpaper
It needs to exported from the PDF as a image file like jpg, bmp, png... but to export it you may need Adobe Acrobat not just the reader. PDF files tend to locked. You could also capture the picture from the doc with print screen, but you will loose the original resolution.
Once you have the file exported, just open with Windows Picture viewer and set as backbround.
Jan 03, 2013 | Dell Latitude E6410 Notebook PC - Intel...
I have steinberg clean 4 & 5 but both versions only show CPF file choice .i want to save as wav.
On the File menu you will find an option named "Export Audiotrack as WAV" as well as "Export Audiotrack as MP3". This will allow you to Save or Export the files you create as either the .wav format or the .mp3 format. Check your Help file, specifically page 86, if you need further information.
Mar 17, 2011 | Pinnacle Steinberg Clean 4.0 (210100265)...
I've created a document in iwork using an iwork template and I want to save it as a word document. However when i save as a word doc the character borders are not supported and removed and the shapes are...
Sharing/Exporting as a word document causes the file to be converted. Certain elements may change on your file and unfortunatly there isn't much you can do to prevent this. If you want your document to look exactly the same on a PC, Share/Export as a PDF document. You can view and print the file on a PC but it can not be edited.
Feb 02, 2011 | Apple iWork '05 for Mac
Can you convert micrografix draw files to another file format
Each Micrografx Designer 3.1 *.drw file should hold one page of drawings, and that one page should be at page 1 in the Micrgrafx layout.
Corel Designer Technical Suite X5 has a free 30-day trial period. This program will import a Micrografx Designer *.drw file and let you SAVE AS or EXPORT AS an *.svg file.
Many current drawing programs, e.g., Visio, can import this *.svg file and let you save as a *.vsd file.
But if your *.drw file contained many pages of drawings, your converted file will have many pages of drawings but often in a single large page that you cannot edit. So safer to start out with *.drw files that each contain one page, and that one page should be drawn at page 1 within Micrografx Designer.
I have used the above method to convert very old Micrografx Designer 3.1 *.drw files to Visio *.vsd files. One problem was the Greek letters that were italics in the *.drw file are not italics in the *.vsd file.
Dec 15, 2010 | Micrografx Windows Draw Graphics & Print...
How do I convert Outlook 2003 address book to contacts so can be used in Outlook 2007.
click on file..import /export export everything as a PST file (export to a file option) this file can be used to import everything back into 2007. If you are upgrading to 2007 it should sort itself as it upgrades
Dec 30, 2009 | Microsoft Office Outlook 2003 for PC
HP OfficeJet 7680 will not print pdf files.
Put an Acrobat Reader to read your PDF, like version 8 or latest 9. To open a PDF is only an Acrobat Reader and can print also in it.
PDF file format are made and construct by an Adobe Professional software and have a realiable to save as your file into PDF, WORD & etc.
Jul 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
Error code: 0XEB020B88 when I try to burn music CD's with cyberlinkDVD suite
do the following
Open Notepad (START>>>RUN>>>type in notepad)
Hit OK
Copy the contents of the CODE box, not including the word "code"
Paste it to the empty Notepad file
In Notepad click FILE>>SAVE AS
Change the Save as Type to All Files.
Name the file as Export.bat
CODE regedit /e Export.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}"
Double click on Export.bat, a text file called Export.txt
should produce on your desktop
Copy>>paste back here the contents of Export.txt
Jun 23, 2009 | Computers & Internet
Export two pdf with one indesign file in a single click
There should be an option as it is in QuarkXPress where you can specify the page numbers and create PDF's for them in one click
Jun 16, 2009 | Adobe InDesign CS2 for PC
Cannot export from OMNIPAGE SE (mac), 10.1.0 to WORD
I believe I can help you with this. What is the format of the page you are exporting from? Also, how many images files are there and what is the size of the file you are exporting from?
I know that MSWord has size limitations on documents which is 32MB, so most like the exporting document contains images that in total is greater than the size limit.
Check out this article by Microsoft--> http://support.microsoft.com/default.aspx?scid=kb;en-us;211489
I hope this helps,
Thanks, Raph30
Jan 27, 2009 | ScanSoft OmniPage Pro X 10.0 for Mac
Apple MacBook Air Logo
48 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
