Question about Exercise & Fitness
Nordictrack exp 1000X will only run on pre-programmed
    Top Expert:
  • 12,223 Answers
When in Demo Mode, the console will go through a repeating lighting pattern. This mode will only become active when the treadmill is plugged in, the main on/off switch is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be turned off at any time.
ethod #1 to switch from the Demo Mode:
1.the STOP button while inserting the safety key tPress and hold o enter the user information mode.
2.Look in the Calories window. When Demo Mode is active, the letter 'd' will appear.
3.Press the SPEED DOWN button to toggle the mode on and off.
4.Once the mode is set as desired, remove the safety key.
Follow the steps and fix it.
God bless you
Posted on Jan 18, 2013
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: My nordictrack exp 1000x keep shutting down after
You may have a belt and deck problem. Test by the following procedure:
without the power on stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time.
Posted on Jun 13, 2010
  • 48 Answers
SOURCE: NordicTrack EXP 1000x: If I run faster than 7.4
hi
it could be two reasons
1 belt and deck--solution (lubrecate it with good spray lube(home depo)and try it if it changes it is belt and deck
2)motor brushes(less possible),
it happens when drive motor draws more amps cause of belt or motor brushes but note that you need to lubricate the belt and deck so it will clear it away
Posted on Nov 23, 2010
2manyhobbies
  • 128 Answers
SOURCE: I have a Nordictrack exp
Right next to the power cord is a circuit breaker. Check it to be sure it has not tripped. If so, reset the breaker.
Check the outlet, be sure there is power.
If that checks out, remove the motor cover (unplug the machine from power first) and check the fuse on the controller board. Chances are if the fuse is blown, the controller might be defective. Replace the fuse and try the machine. If it blows again, the controller is defective..
Posted on Dec 17, 2010
ercupa190
  • 12223 Answers
SOURCE: speed is off on nautilus exp 1000x treadmill
Please use your calibration software for recalibration your fitness according with your owner manual. See the instruction too below the hood. and proceed for fix it.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a
Posted on Dec 19, 2011
How do i turn on a nordictrack treadmill exp 1000 x
they have a small switch Red in lower part to the side to the power cord.
see you instruction manual, or download free www. iconservice.com
God bless you
Jun 17, 2012 | Nordic Track Nordictrack Exp 1000...
Speed is off on nautilus exp 1000x treadmill
ernesto cuadra
Dec 10, 2011 | Exercise & Fitness
I need a mannual for my nordictrack exp 10000 xI. Can you help?
Here is a list of many different versions of the NordicTrack Exp 1000XI. If you know your exact model number you can click on your version and view a parts list and purchase an owner's manual. If you just need to look at a diagram of all the parts many of the equipment pages have that available to view for free. Hope that helps.
Sep 12, 2011 | Nordic Track Nordictrack Exp 1000...
I have a Nordictrack exp 1000x and it won't turn on. Any ideas?
Dec 17, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a norditrack exp 1000x, on the lower part,of the control panel,the functions,have stopped working.but the upper function keys are ok.what do think is wrong.?
The overlay is bad. You will need to replace the whole console because nordic track does not sell just the overlays. you can get the console at iconservice.com or check on ebay
Aug 11, 2010 | Nordic Track Nordictrack Exp 1000...
My nordictrack exp 1000x keep shutting down after it runs for a while. then i have to restart it and it will run for a while and shutdown again.
Jun 13, 2010 | Nordic Track Exercise & Fitness
Have a nordic track exp 1000x treadmill and the belt is slipping
my nordictrack exp1000x doesn't elevate anymore, what can be the problem and how can i fix it?
Nov 01, 2009 | Ironman Fitness Achiever Elliptical...
Exercise & Fitness Logo
107 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
