Question about Kinyo PW-8899 Wireless Stereo Headphones
Wireless headphones Transmitter light not on
    New Friend:
  • 39 Answers
Maybe your headphone has broken. You can buy new one from Mubuy
Posted on Jan 19, 2013
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Windows xp - ms bluetooth adapter dongle - motorola s305 headset
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity.
Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection.
PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones.
Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter.
Wireless headphones require power to function.
Many wireless headphones come with a charger base.
You need to charge your headphones before you attempt to connect them to your PC.
Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC.
Connect the transmitter to your PC.
The transmitter may connect via the PC's headphone jack or USB port.
If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter.
If the transmitter connects via USB, you will likely need to install software to use your wireless headphones.
If your wireless headphones are Bluetooth-compatible, continue to the next step.
Pair your headphones via Bluetooth to your PC.
If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle.
Turn on your headphones and open the Bluetooth software on your PC.
Scan for Bluetooth devices from your PC.
Your headphones should appear.
Select the headphones and follow any further instructions to complete the pairing process.
Test the headphones.
Pick out a song or a video and play it on your PC.
Connect your wireless headphones and verify that you can hear the audio.
Find the volume controls on your headphones and adjust them to make sure the volume changes correctly.
If your headphones are not functioning properly, verify that the headphones are turned on.
If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC.
Recharge your headphones when you are finished using them.
To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them.
If the headphones are battery-powered, be sure that you always have spare batteries on hand.
Jul 18, 2013 | Microsoft Bluetooth v2.0 USB Dongle...
How do I get my Slick HP 921 Wireless headphones to work
  • Goodmorning, I received Slick HP921 Wireless Headphones yesterday I have perfectly utilized them yesterday but today I have no communication between the wireless transmitter and the wireless headphones without changing anything since yesterday.
    The wireless transmitter is turned on but it's not trasmitting. The headphones work perfectly with fm mode and also when i connected the single green plug with other devices ( pc, phone ).
    The problem should be in the wireless transmitter.
    What I have to do ?
Dec 26, 2012 | Audio Players & Recorders
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
My Freepulse headphone won't pair anymore. Both components charge, both both of them display the red LED light. I've tried the override button on the transmitter, and I've tried holding the power button...
You hold the button on the transmitter for about 50 seconds - light flashes red, solid red, goes off and then flashes blue and red. Then you can do the same on the headphones. Then wait and they should pair.
Jun 29, 2010 | Logitech FreePulse Wireless Consumer...
No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Mar 03, 2009 | Sennheiser HDR 140 Consumer Headphones
Logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Feb 27, 2008 | Logitech (980361-0403) Headphones
Setup Bluetooth Wireless headphones
Each brand has it's own peculiarities and you did not specify the brand. I would suggest turning off the headphones, resetting the transmitter (turn off and on again for separate devices) and then pressing and holding the 'on' switch for 15 seconds or so. You may see (in some models) a light start to blink blue then red and back. This should indicate that the receiver (headphone) is trying to find a transmitter to pair with. Hope this helps.
Nov 27, 2007 | Logitech Bluetooth Wireless Headphones
Wireless headphones
If you're handy, you could rig up a wireless solution to this. The problem is that you have two screens, each presumably playing a different movie. If you purchased an off-the-shelf wireless transmitter accessory, you could connect it to one of the screens. But then if you purchased a second wireless transmitter accessory, and connected it to another screen, you would need to make sure both wireless transmitters were operating on different frequencies, so that each person could wear a different pair of headphones and listen to their own movie. Hopefully this makes sense. You could use either an FM Modulator to do this, or an Infrared Audio (IR) transmitter... Remember, these units aren't like factory installed headrest systems; they don't have the wireless audio transmitter already built-in, so you can't just buy wireless headphones and listen to them.
Aug 17, 2007 | Venturer PVS62911 Car Video Player
Kinyo PW-8899 Wireless Stereo Headphones Logo
41 people viewed this question
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Larry Chandler
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
