Question about Sony VAIO Computers & Internet
Just set up new sony vaio computer but when I try and tune in the tv it says antenna required. Anyone know what antenna I need to get?
Its a touch screen all in one PC
    New Friend:
  • 86 Answers
Antenna in d sense the cable connection.......
Posted on Dec 27, 2013
  • 108 Answers
SOURCE: Sony VAIO PCV-V100G PC
yes reinstall the tv tuner software.
there might be some other applications conflicting the same.
Posted on Feb 04, 2008
CompuGuy44
  • 432 Answers
SOURCE: sony vaio tv tuner card and tuner card driver problem
You'll need to go to the sony website and download the MPEG encoder Driver. http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCVV200G&upd_id=1415&os_id=7.
You might want to download the latest update drivers from this site also.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVV200G&LOC=3
Posted on Feb 14, 2008
Smoking_gnu
  • 38 Answers
SOURCE: Replacing the powersupply on a Sony VAIO PCV-RS720G desktop
Hi There,
From the looks of things that model will take a standard ATX power supply which would be available from and computer part dealer and ebay etc, get yourself a nice 400w replacement try and get a small form factor one if you can as it will be a tight sqeeze inside the case.
when replacing it you will have to open the case up (get an anti static wristband if you can, and work on a table rather that a carpeted floor) un hook all the connectors the old power supply (one in each drive and there should be 2 in the motherboard) you may have to pull the Dvd rom out slightly to get the new supply in, unscrew the 4 case screws holding the power supply from the back of the case. lift it out then put in the new one, screw it in using the case screws and connect up the internal power cables to the drives motherboard and new graphics card, close the case, plug in and voila
If you get stuck just ask and we will help
Posted on Dec 10, 2008
  • 111 Answers
SOURCE: Does Sony VAIO VGC-RC110G PC Desktop has digital tv
no computers are digital anyways
Posted on Dec 21, 2008
  • 20 Answers
SOURCE: Sony VAIO PCV-RX500 Cant get recovery cds to work
since she formatted the hard drive there is no drivers for your cd rom to work
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
Posted on Aug 21, 2009
How do you set up an SP-813 indoor TV antenna?
There's not a lot to this antenna; nor much in the way of knowledge required to set it up. Connect a length of coax cable from the F type screw connector on the antenna. Connect the other end to your TVs antenna input. Plug in the power adapter. Switch on the antenna and set the gain adjuster to the half way position between min and max.
Now look at your neighbours properties. Which way are all their antenna pointing? Point yours in the same direction.
If you know what channel on the tuning scale the local TV stations use for broadcast then tune your TV manually. Then fine tune gain and direction of the antenna for best reception. If you don't know the tuning channel it's a bit more pot luck. Let the TV do an auto tuning and hope you have not too much or not too little gain and the antenna pointing in the right direction.
Sep 03, 2014 | Televison & Video
Cant retune through dvd player
Sounds like a few things going on here... Your indoor antenna for one is probably not making it easy for you as an outdoor antenna will work a whole lot better. This is why it open picks up half the channels and they are pixelating. Also you may have faulty rf leads. Replace these.
Feb 25, 2014 | LG Televison & Video
My sony vaio pcv-f11m tv will not tune in to the aerial
Is the TV adapter digital ready. Try a cable connection. Digital antenna.
Nov 29, 2012 | Computers & Internet
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
Tuning a sony trinitron tv
Most of the sony TV's comes with an auto tuning facility and all your need is ensure that the RF inout/cable TV or antennae is plugged into before the auto tuning is activated.
The auto tuning is available inthe older models on the set and in the newer models on the remote control. Choose program menu , tuning, auto mode.
Also you can search inthe manual mode individually and preset the channels position to your convenience such as news channels together, movies together etc.
Sep 21, 2010 | Televison & Video
Sony Vaio touch pad, mouse scroll and USB ports not working
Here is the required drivers for the Computer.
Touch pad, Mouse scroll=> Download
USB Ports=> Download
Hope this will help.
Sep 29, 2009 | Sony VAIO R505EL Notebook
Screen on tv just says no signal
When installing a new antenna, a TV will often need retuning in order to operate with the new antenna.
Using your remote, access the TV's menu (settings as oppose to TV guide) and you should be able to access a tuning menu, this may be located in Picture, or have its own section.
Select the setting for automatic tuning and you should find that the TV uses the new antenna to find its channels.
Aug 23, 2009 | Televison & Video
Powers off randomly
howlond does your laptop stay on? does it show any messages prior to shutting down? does the computer feel hot on the bottom?
let me know.
Apr 10, 2009 | Sony VAIO VGN-FE780G Notebook
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Tuning Sony KDL 32U3000 for Sky TV
Hi Max,
I an not familiar with Sky TV, I assume it a Cable or Satilite Service.
Here are a few things to check.
  1. Press the INPUT button on the TV remote or on the TV control panel, cycle through all inputs and see if you get a signal.
  2. From the TV's Video Menu, set tuning band to Cable and not to Air or Antenna.
  3. From the Video menu Scan for channels, there should be a Auto Scan option.
Try these and let me know how it goes, I can be of further assistance.
Lone99star
Feb 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Computers & Internet Logo
37 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
